| diyAudio Sponsor | ||
Hello, I am thinking of making a 5-1 tube amplifier for my room. Since 5 channels must be used this is 5x the cost so I have chosen a simple design (a better suggestion??)
I have found these two litle integrated amplifiers and I would like to have some suggestions of which one to use, based on sound quality and volume factors Thank you
Great DIY site: http://www.neazoi.com |
#2 |
Availability considerations force you to use the 6BM8/ECL82, as Russian production is in the market place.
A PSU using an unsymmetrical 1/2 wave rectifier is a BAD idea, as "standing" DC is present on the rectifier winding. Check this thread out. A Triad N-77U in the B+ supply is good for approx. 225 mA. That might be enough for 5X channels. The N-77U has dual primaries and works in both "120" and "240" VAC zones.
Eli D. |
#3 |
They both look bad circuits to me. The ECL82 one is dangerous.
#4 |
ok, they are quick-n-dirty, and cheaper. a safer psu in the ecl82 one is essensial.
have you got an alternative to propose?
#6 |
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#7 |
Go for the beefier ECL86. The pentode can be looked upon as a EL84 with 9W instead of 12W Pa and the triode is one half 12AX7. It sounds great and is available NOS. Probably the P will be cheaper.
If the driver feels wimpy you can always add a DC-connected MOSFET-follower between triode and pentode. But why not go PP? Easier to get hum free and better performance by adding just one tube.
Brgds Lars |
#8 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
Thank you all,
I have also thought about OTL (direct coupled or even with capacitor coupling to the speakers), which eliminates the output transformer and reduces cost, but it seems there is nothing around using small tubes...
#10 |
OTL with small valves means headphones only. This is because of a basic impedance mismatch between transducers and valves: loudspeakers have impedances in the ohm range, valves have impedances in the Kohm range. You either need a transformer to match the impedances, or use lots of valves in parallel to reduce the impedance and, also, heat the room.
| beginner's ecl82 | skyraider | Tubes / Valves | 30 | 18th October 2011 02:46 PM |
| Mullard ECL82 6BM8 | john65b | Swap Meet | 3 | 24th August 2010 02:35 AM |
| Ecl82 | alexandar888 | Tubes / Valves | 15 | 10th May 2009 07:39 AM |
| ECL86 preamp? | Hanzwillem | Tubes / Valves | 23 | 16th June 2007 11:45 PM |
| ECL82 Headphone amp | mod_evil | Headphone Systems | 9 | 8th April 2007 10:31 PM |
| Page generated in 0.09414 seconds (78.71% PHP - 21.29% MySQL) with 11 queries |
