diyAudio Sponsor
Old 14th June 2010, 06:00 PM   #1
phrarod is offline phrarod  United States
Default Oscillating PSU above certain voltage
I'm finishing up my pre-amp project and while I wait for iron for the new mono supplies I designed I'm having issues with regulated supply I need to work for the next couple months.
Its been working fine for the last 1.5 years but suddenly when I now adjust for target voltage/bias amp it goes into oscillation. Since I never had it at this voltage/amperage before I'm wondering if the supply or PT are being over taxed.
My target is 200VDC with 12mA of bias. The PT is a 1A HV.
In that past I've had it up to 240VDC but only at 6mA bias voltage. I spent the whole weekend troubleshooting and found if I adjust past 195V which is roughly 11.4mA the PSU begins to go into oscillation.
All the resistors, capacitor, tubes check out fine. I included the schematic. Maybe a PSU master can tell me what's occurring?
Old 14th June 2010, 06:51 PM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
What's the frequency?
I mean, infrasound, sound, or ultrasound? If infrasound increase C1 so the amp will be always in linear mode.
Does VR tube flash?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 14th June 2010, 06:55 PM   #3
I don't have any test equipment beyond a DMM and my ears. I get a low frequency hum mixed with some high frequencies and ticking sounds.
Old 14th June 2010, 06:56 PM   #4
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Circuit comments:
What's C1 for? Why are C2 and C3 films? There isn't an electrolytic in the world that has too much ESR for this work (and honestly, you're fooling yourself if you think anything else could make a difference!).
V3 is biased quite low, or actually, very unbalanced. There's hardly any current through R3 as shown, yet (I'm guessing) ~5 times more when the output is unloaded. For better performance, it should be sourced from C2. Or you can eliminate the balance issue by using a pentode (put V4 in the cathode circuit), which will improve gain nicely as well.
Several voltages listed are impossible. Check your meter, I guess. For instance, how can there be apparently 40VDC across the 5AR4 heater? The inductor also seems to be dropping 100V. R7 seems to have 5V across it, suggesting a load of 50mA (you did not state under what conditions these measurements were taken). Maybe the 29H actually drops 100V under load (2kohm?), I don't know. It will get quite hot if it's true.
As for stability,
Your number one problem is C3 putting a big steaming pole in your response. You probably need bypass caps anyway, so you pretty well have to deal with that one. Maybe it doesn't need to be as big, but that's just changing the frequency anyway, which is approximately 1 / (2*pi*Zo*C3) = 14Hz.
Now, this seems to be more than low enough to put a damper in anything that could happen, and you didn't say what frequency, amplitude or waveform the oscillation is, so I have to guess here.
I do find it odd that you have extra delays around the error amp. I guess R6 is a grid stopper, and C4 is a "speedup" cap, enhancing HF gain slightly, and adding some leading phase, which will help compensate for the R6-miller C-R3 system. It looks odd to me that C4 is at the output though. I'd put it on V2 cathode. As shown, you'll get phase shift from the R7-C3 system, which will be 90 degrees (and lowww gain) at higher frequencies.
That said, I don't think it's a control loop thing. Even if it were oscillating, and at high frequency, there's probably enough phase shift in the system to do so, but with C3 there, you won't even see it, it will be too heavily swamped.
Sooo, check V4 and see if it's buzzing. With only 2mA (if the voltages are correct), it's not even running in the recommended range. If you need idle current that low, use a 0G3 (85V, 2mA), or zener diode, or smaller bypass cap (or none at all), or more bias.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 14th June 2010, 07:00 PM   #5
Wavebourn's Avatar
Originally Posted by Sch3mat1c View Post
Circuit comments:
What's C1 for?
For higher rectified voltage. If to increase it a bit the regulator may be stable on higher output voltage/current, if oscillations are caused by clipping of the EL84 tube.
Old 14th June 2010, 07:05 PM   #6
Wavebourn's Avatar
Speaking of ticking, 30K may be too high value: I would consider 5 mA of current as a minimum for a VR tube.
Old 14th June 2010, 07:24 PM   #7
Wealth of info! Thanks everyone.
First, this supply was purchased on eBay as a one modeled on the Jadis PSU.
I changed it to a choke loaded PSU. Yes, C1 changes voltage.
It originally came with a OC2 diode but once I went to choke loaded I could not get enough B+ so I went with the OA2.
I the voltage on the 5AR4 was just Pin 8 to ground not across the heater. That voltage is dropped by 10VDC by the choke. I made an error on that schematic. Thanks for catching it. S/B 390vdc Consider the rest of the voltage accurate +/- 5V.
I will retake the readings again later in the day. The readings in the regulated section are a little old but my new readings were within +/-5V.
The film caps (ASC X386S) sounded far superior to the initial electrolytic that were in there.
C3 originally had a .1uF bypass in the circuit but my friend told me it was not necessary with a film cap so I removed it. I thought about maybe that could be one of the causes?
Old 14th June 2010, 07:53 PM   #8
I had a break and took all new measurements. Attached.
Old 14th June 2010, 08:00 PM   #9
Wavebourn's Avatar
Once again, please try to increase C1 and decrease R4.
Old 14th June 2010, 08:05 PM   #10
C1 increases voltage. Its just a voltage set. I don't believe this is an issue as a friend runs his non regulated supplies this way.
What size do you recommend to try for R4? What target voltage am I looking for there? I just looked at the OA2 data sheet and it says min anode is 185VDC. Yikes!
Sooo if I just run a jumper wire it would see 196VDC. Or I could just use a small resistor to bring it to min but I usually run tubes over min naturally. Possibly a dumb question but if I increase plate voltage will the overall PSU output be increased? I need to keep it within the range I have set although I can always play with R8 again to change the voltage range.
I suspected it had something to do with the OA2 tube since I swapped it in there replacing the OC2 tube.
Difference between self oscillating and non-self oscillating D-amp. sildex Class D 36 4th August 2010 03:30 PM
Self Oscillating (Oscillating Calculations) Help! Reactance Class D 7 12th March 2010 07:37 PM
Reducing PSU Voltage hernanstafe Parts 1 9th March 2007 05:14 PM
PSU oscillating apolon34 Power Supplies 3 24th June 2005 02:20 PM
Raise psu voltage m60gpmg Solid State 6 5th September 2004 12:15 PM
Page generated in 0.11540 seconds (79.81% PHP - 20.19% MySQL) with 11 queries
