just received my ming da 34ab today and can't help notice the smell coming off of the power supply. it's thick odor is reminiscent of drying paint and is present even with the amp turned off and cooled down for a while. im reading on a website that its a transformer glue smell. what chemical is it exactly? how hazardous is this odor to my health? and when can i expect it to go away completely?
#2 | |
I buy Chinese made power transformers regularly and they are generally quite aromatic when new. The custom ones I used to get made here were pretty stinky as well if memory serves.
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#3 |
thank you. i want to believe that's the case also. and if so, please tell me how long did you notice it for your transformers to finally be free of the smell? what steps can i take to bake it out faster? i've already planned to put the amp in a separate room but also thinking of taking off the humphy cover if aeration helps.
#4 |
ttt i would very much appreciate further info since i'm having no luck with googling on my own. thanks :P
#5 | |
Basically just put the amp in another room or open the windows and let it run for a few hundred hours. It's good to break in the tubes and caps too. |
#6 | |
Never leave any tube amplifier on for long periods of time unattended unless you like fires. Most domestic tube amplifiers are not designed for long term continuous operation. The smell will burn off in use, just provide good ventilation during the time you are using it, typically a couple of hundred hours will be required..
#7 | |
| Ming Da MC368-B90 | ManUtd | Tubes / Valves | 2 | 18th October 2012 07:49 AM |
| FS: ming da mc84a tube amp (non nos mullard included) | PreSapian | Swap Meet | 1 | 4th January 2010 04:39 AM |
| Ming Da transformer problem? | RobWilJr | Parts | 1 | 10th May 2009 03:10 AM |
| Ming Da MC-34B fuse value? | cscmc1 | Tubes / Valves | 1 | 26th October 2008 07:46 PM |
| Ming Da MC34B....passive or active pre amp? | Paul Dimaline | Tubes / Valves | 2 | 29th January 2006 07:35 PM |
