diyAudio Sponsor
Old 14th June 2010, 04:29 AM   #1
haroT3k is offline haroT3k  Canada
Default Rebuilding my amp, would like some input.
Hi Guys
I bought a Decware MLB from head-fi a year ago, and loved it. But i found that the bass impact was somewhat lacking. I've asked Steve at Decware on how to resolve this, and he told me to try changing in higher valued coupling capacitors which worked out pretty well. However, the internals are pretty tightly packed, so I want to rebuild the amp with better spacing, so i can roll capacitors more easily. So while I'm at it i would like to ask if there are other ways to improve the amp. Also theres a 0c2 voltage regulator tube, I was wondering if i can switch it to a 0a3 or 0b3. Thanks
The Rebuilding of Theta KT-88 Tube amp. Maniac Tubes / Valves 42 5th May 2011 04:12 PM
Tips for rebuilding this amp? Ty_Bower Tubes / Valves 24 4th April 2007 03:02 AM
rebuilding an amp...from a megaphone... nerd of nerds Chip Amps 1 27th November 2004 12:21 AM
rebuilding 6L6 amp ... suggestions? phonon Tubes / Valves 67 17th April 2003 12:27 AM
I'm rebuilding my amp Lisandro_P Everything Else 2 4th July 2002 08:53 AM
Page generated in 0.06197 seconds (64.68% PHP - 35.32% MySQL) with 10 queries
