diyAudio Sponsor
Old 13th June 2010, 04:37 PM   #1
vitalstates's Avatar
Default harmonic distortion
I was going to tack this on the end of the gimp's thread but thought i might dilute or derail it.....
I am not really sure or confident of what I am presenting here, so I am asking for some idea of the rightness or wrongness of this approach to measuring amplifier harmonic distortion. I have found some articles on the net but they all seem to point to expensive test equipment or an array of notch filters, cumbersome or expensive.
I have constructed a clamp/buffer so that I can safely feed the amp output into a cheap pc soundcard. After a few trials I elected to use roughly 3:1 voltage divider in the buffer so that 2.83 volts across 8ohms(1 watt) from the amp, produced 0.775vrms(0db) into the soundcard.
feeding a 1k signal from the sig-gen into the amp I measured the harmonic spectrum using a spectrum analyser(in this case the span vst plug from voxengo) and produced the chart shown.
Taking the dbu values of the harmonics shown I converted them into rms voltages(dB dBu dBFS dBV to volts conversion - calculator volt volts to dBu and dBV dB mW - convert dB volt convertor converter calculation online attenuation loss gain ratio reference audio engineering sound recording dBFS dBVU 0 dB audio logarithm level con), added them up, and then found the total as a percentage of the fundamnetal, i.e 0.775v i.e 0db.
from the example shown, which is a 2A3 with 6sl7 srpp driver, I found the following values:
F2....-39dbu-----0.008 vrms
F3....-49dbu-----0.002 vrms
F4....-68dbu-----0.0003 vrms
F5....-81dbu-----0.00006 vrms
giving a total of 0.01036 vrms which I think is about 1.33% thd
given the innacuracies of the equipment, does this sound like a valid method to get a rough figure for thd.
Ed
There is nowhere you can be that isn't where you're meant to be
www.vitalstates.org
Old 13th June 2010, 04:58 PM   #2
Svein_B is offline Svein_B  Norway
-40 dB (compared to the fundamental) corresponds to 1% distortion,
so your math seem to be about right.
If you have not already done so, you should also make a measurement of the output from the tone generator so you know the source distortion and thus your measurement limits.
In order to know the exact level of the measurement, I find it practical to use a good multimeter on the output, since calibrating the soundcard with attenuator and input volume control is a bit unpractical.
Svein.
Old 13th June 2010, 05:06 PM   #3
Hi Svein
thanks for the look, and thanks for the basis of the clamp/buffer, it was your circuit I started with.
I did calibrate the i/p to the sound card with a dmm, but my dmm is more suspect than my maths.....but 0.775 in did indeed present 0db at the s/w input.
I ran the sig gen(Farnell LFM4) through before I started and all I could get was the fundamental on the chart, right down to -110......
Ed
www.vitalstates.org
Old 13th June 2010, 05:16 PM   #4
Michael Koster's Avatar
Ed
I'm pretty sure that THD is the power sum of the harmonics, not the voltage sum.
The power sum would be obtained by summing the squares of the RMS voltages (power = voltage ^2), then taking the square root of that to get back to RMS voltage to calculate THD. In your example it should work out to about 1.06% THD
Michael
Old 13th June 2010, 06:21 PM   #5
thanks Michael
I've just discovered the wiki article, i.e exactly as you describe.....
I guess I should have looked there first...doh!
www.vitalstates.org
Old 13th June 2010, 06:57 PM   #6
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
The valid method is to observe spectrum in dynamics and decide is it "natural" or "alien" to our perception: from very low to the max output. For the reference, "natural" spectra are results of non-linearities in an air, wood, stone, and so on, depending on degree of excitation.
THD is like an average temperature of patients in the clinic: it may be used to determine what kind of clinic is it. But can't provide an information about conditions of each of patients, and what they need to be healthy.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 13th June 2010, 07:11 PM   #7
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
[snip]I have constructed a clamp/buffer so that I can safely feed the amp output into a cheap pc soundcard. After a few trials I elected to use roughly 3:1 voltage divider in the buffer so that 2.83 volts across 8ohms(1 watt) from the amp, produced 0.775vrms(0db) into the soundcard.[snip]Ed
Hi Ed,
What 'clamp/buffer' did you use? If it is some form of diode clamp, the distortion of that can easlily swamp the amp distortion.
It would be best to use the resistive 1:3 divider only (and just be carefull with that level control ).
jd
/Another new issue: Linear Audio Volume 3!
Old 13th June 2010, 07:53 PM   #8
richwalters's Avatar
Notice: Never leave a reference or comments off graphs..it's the quickest way to loose relevance to nothing. Put text on it.
On amplifier testing I always refer to full o/p as a 0dB ref (an old RF habit)with text details on side. Remember dB scales mean nothing without a reference to what is referrring to. (be clear)
Fractional dB scales are a pain in the a'se and aren't necessary. Power Scaling on 10dB/div on graticule is convenient; the rule of thumb becomes a doddle to work out... in this way, 60dB down becomes a thousanth, so as the ref is 100% then 60dB down must be 0.1%. Simple ! So if you study this more closely one can arrange work in display graticule sections of 10dB:-
100%,= 0dB
30%,=-10dB
10%,=-20dB
3%, =-30dB
1%,=-40dB
0.3%,=-50dB
0.1%.=-60dB
and so on, off by heart.
So picking off harmonics and knowing roughly the level should be kids play.
The example graph is an example.
I always work in plain dB and add the comprehendible rest to what one uV/V etc one is referring to.
Remember; on soundcards or digital scopes with FFT spectrum options, the setup is important. When asking it distortion % measurements there may be a box "harmonic detector" with a pull down 1-8. If one is using an old analogue thd meter, then it will be averaging to the
3rd any perhaps no higher. To get close to the similiar result, select the same.
The results will never be identical from one equipment to the another but be in the same ballpark.
I hope I've left no-one confused, but it's darned simple when you know how.
Everyone on the bench should also know the rule of thumb reactance of a 0.1uF cap at 1Khz = ~1600 ohms. From this one can figure out all the other combinations.
richy
Old 14th June 2010, 03:40 AM   #9
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Ya know, a sticky on the subject of Distortion, Distortion Measurements (and probably grounding as well) might be helpful for a lot of people.
Old 14th June 2010, 08:57 AM   #10
Originally Posted by janneman View Post
Hi Ed,
jd
hi Jan
at the moment I've got opposing 2.4v zeners across the bottom leg of the divider. I will remove them and see if changes the figures.
thanks for the tip
Ed
www.vitalstates.org
Harmonic Distortion In Maggies JimOfOakCreek Planars & Exotics 2 20th April 2008 04:04 AM
Why is distortion harmonic? dsavitsk Tubes / Valves 48 12th March 2008 02:49 AM
What effect does a TL have on harmonic distortion? owdi Multi-Way 0 26th April 2006 03:55 PM
second harmonic distortion tenderland Tubes / Valves 5 5th August 2004 11:29 AM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
Page generated in 0.13690 seconds (82.33% PHP - 17.67% MySQL) with 11 queries
