diyAudio Sponsor
Old 13th June 2010, 01:05 PM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default Enhanced Tube's performance
see my best preamp
that works at +/- 25V
an have firs stage in voltage gain
and second in current gain
visit my best audio idea http://www.esafono.it/DACTONE.htm
Old 13th June 2010, 03:26 PM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
It doesn't work. You haven't tried it, huh?
Old 13th June 2010, 05:28 PM   #3
Multiple CCS in series, the lesser or stiffer one wins.
It might "work", but not behave exactly the way your design implies.
Your anode "active loads" are not active as drawn, they are CCS.
Well, whichever end is set to the lower current limit becomes the CCS.
The other is only a resistor, maybe in series with some sort of a diode...
Operating wide open, cause it never reaches the threshold for limiting.
Old 13th June 2010, 06:07 PM   #4
Stee's Avatar
Default yes it works
but is wrong design
Judging a tube's condition db! Tubes / Valves 2 11th February 2010 03:46 AM
tube's tempdrift SemperFi Tubes / Valves 1 3rd April 2002 12:43 AM
Page generated in 0.07192 seconds (70.04% PHP - 29.96% MySQL) with 11 queries
