New GU50 SE: SRRP or Cascode for driver?
Old 13th June 2010, 01:51 PM   #1
Globulator is offline Globulator  United Kingdom
Globulator's Avatar
Default New GU50 SE: SRRP or Cascode for driver?
I'm looking at a new SE design (a Sweet Peach rebuild) with the GU50 output tube in pentode mode at 430V, with a 6N6p driver tube at B2+ = 400V and a 6N3p input tube at B3+ = 350V. The concept is feedback only around driver+output to present a low impedance to the OPT.
So far so simple. So I can use a whole tube or a half tube for each section. I could use a CCS on the anode but I would have to buy those - whereas I have tubes here right in my hands...
The input stage: Needs to be simple, linear, lowish gain.
The driver stage: Needs to be linearish, high gain, good voltage swing
The output stage: Pentode mode, Anode 430V, 55mA idle, Screen at 250V?
Feedback will be from the GU50 output tube (anode or cathode) to the driver tube cathode or grid - ideally without a capacitor but probably will need one.
The input and driver stage can be GC ('grounded' (unbypassed) cathode, SRPP or Cascode. The SRPP and Cascode can be SRPP+ or UL Cascode courtesy of TubeCad's papers.
My idea is to use 7mA on the input 6N3p and 15mA on the driver 6N6p to get them linear.
Plan1: Input CG, driver SRPP+, feedback from GU50 anode to driver cathode.
Er.. I only have one plan at the moment
So could people comment on the choice of SRPP vs Cascode please - I'm a bit lost as to the practical difference between them!
Old 13th June 2010, 06:59 PM   #2
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
The SRPP has a disadvantage of being balanced for just three load conditions: dead short, unloaded, and the one specific impedance for which it was designed. For every other load it goes out of balance and distortion rises with that imbalance. It really doesn't make a very good grid driver since grids going positive don't represent a consistent load.
You're probably better off using a CCS plate load instead. If you need the buffering, just use the other half of the dual triode as a cathode follower.
Cascodes have two possible disadvantages: limited output swing as compared to the Vpp supply. The cascode also has an unusually high effective r(p) (more in the territory of a small signal pentode) that may not play well with a load that isn't Hi-Z and Lo-C.
I did a project that used 6BQ7s to implement a cascoded LTP, and that worked out great: enough gain from a single phase splitter / gain stage, and the sonics were excellent.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 13th June 2010, 07:08 PM   #3
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
A huge difference Feedback by current (from cathode) would increase output impedance of your amp. Feedback by voltage (from anode) would decrease it.
Some people argue that speakers sound cleaner driven by high output resistance, though. But others argue that frequency response is better when driven by low resistance.
I would try both.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 13th June 2010, 11:01 PM   #4
Globulator's Avatar
OK so I'm not going to implement a CCS right away (because of having to buy the bits), but I suppose I could build first with a simple GC and anode resistor - then upgrade later with a CCS. That would be easy too
I definitely want a very low output impedance driving the OPT, not because I'm convinced it's better, but because I want to hear what the effect is
I'm still a bit confused on a few things though:
a) I thought all pentodes are easy to drive - is this not the case?
b) So what use is a SRPP ?
c) What is a Cascode useful for (besides driving a Schade topology tube!)
Thanks for all the help!
Old 13th June 2010, 11:44 PM   #5
Arnulf is offline Arnulf  Europe
I'm following this thread with great anticipation - I have GU-50s ready, my plan was 6N6P as amplifier/driver (common cathode) and either 6N1P or 6N2P as voltage amplifier (common cathode), one section per channel, feedback routed from the secondary to first stage.
As for your questions:
A: they are way easier to drive than triodes due to negligible Cmiller. Where does one draw the line between "easy" and "not easy" ?
B: line driver (think: transoceanic telco cables - fixed Z load, power gain = good due to cable losses)
C: low Cin at high f (think: UHF circuits before conception of multi-grid tubes); first stage disposes of Cmiller, because it is working into fixed potential (current gain), second stage provides voltage gain with current shoved into its bottom.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 14th June 2010, 06:53 AM   #6
danzup is offline danzup  Romania
danzup's Avatar
As I respect all other opinion , for the last 3 tube amplifier I am using SRPP as a driver .
For Gu50 in SE I am using SRPP with 6n2p and it work exceptional well for me .
FYI : I do not use feedback at all in SE , NEVER .
Why do not make some experiment ( as in trying all the circuit you mentioned ) and decide what is best for you ?
I have done such test for driver :
1.simple triode
2.pentode
3.triode with choke on anode
4.SRPP
5.Cascode
6. cathode repeater with triode
and the result was that number one for my ears ( best ) : 4.SRPP !!!!!!!
second place was : 6. cathode repeater with triode
last and the most crappy one : 3.triode with choke on anode
There are not better tube than 6P3S and 6N2P for my ears !
Old 14th June 2010, 10:34 AM   #7
Globulator's Avatar
Wow danzup, that was a comprehensive test!!
Intuitively I think the SRPP should work the best - I was puzzled why so few used it. My reasons why I thought it should work are:
a) It suits swinging the voltage well. For an SE you need a lot of drive voltage, and I suspect SRPP would be trying less hard than anything else - no straining against anything at the extents.
b) Output drive. It's used for simple output stages - so it has a lot of power capability. I know the grid of the output tube can be a lot to drive - but so are OPTs with speakers on them. With a reasonable grid stopper on the GU50 the drive should be pretty constant impedance I think - plus a pentode is pretty easy to drive. Sp a 6N6p SRPP idling at 15mA should simply not notice the grid load of a GU50.
So now (as I've now heard the answer I wanted ) I need to decide if I just use the time GC input 6N3p tube in a degenerated anode resistor way to drive this SRPP, or something else.
How easy is an SRPP to drive?
Old 14th June 2010, 10:46 AM   #8
danzup's Avatar
Easy , I use something like this :
CD Player -->pasive R2R Volume --> ( SRPP --> Gu50 ) -->Speakers
On my "home" Romanian forum we build SE with Gu50 in penthode mode and drives by SRPP with following tubes : 6n6p , 6n2p , 6n3p , 6n1p and 6h13s .
For me 6n6p ( 16mA ) and 6n2p ( 8mA ) was the best !
Old 14th June 2010, 11:26 AM   #9
Globulator's Avatar
On my "home" Romanian forum we build SE with Gu50 in pentode mode and drives by SRPP with following tubes : 6n6p , 6n2p , 6n3p , 6n1p and 6h13s .
That's an interesting idea - avoids a stage completely too.
What voltage do you run the GU50 and the SRPP from?
What screen grid voltage do you use for the GU50?
Old 14th June 2010, 11:41 AM   #10
danzup's Avatar
+B = 400V at the Gu50 then a 4K7/3W resistor from +B to SRPP anodic with 470uF/450V and 0.1uF Wima MKP in parallel
For G2 = 250V , with a resistor and 250V zenner to ground and MKP capacitor in parallel with zenner .
( the final GU50 stage is like this Verstärker mit GU 50 in Klasse A–Betrieb )
New GU50 SE: SRRP or Cascode for driver?Hide this!Advertise here!
Shunt Cascode Power Valve Driver Rod Coleman Tubes / Valves 32 7th March 2017 12:57 PM
GU50 SE Amplifier class A , with 6SN7 Full construction details mario2005 Tubes / Valves 118 14th August 2010 06:33 PM
SRRP Output stage. Calculating power output. Cassiel Tubes / Valves 1 1st March 2010 03:38 AM
All FET folded cascode driver for "JLH"-buffer with no GNFB revintage Solid State 10 29th January 2010 10:58 AM
Srrp output question woody Tubes / Valves 11 1st September 2009 02:48 AM
