| diyAudio Sponsor | ||
MFA Lumi started "motor-boating" today :-) Any ideas what is causing it? I have the diagram. My thoughts are: 1) regulator tubes 2) filter caps 3) coupling caps 4) who the hell knows...
#2 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
I would check C35 & C36 for leaking....Going "high".
I would also drop a cap at pin three of your 6L6GC to ground, Appx 1.5uF400+VDC(The 'perfect' capacitor)..I'm suprized there wasn't one in the first place. Just throwing ideas out. __________________________________________________ ____Rick..... |
#3 |
Fixed - bad zener
#4 |
vr3? I capitalized the above reference designator, but the forum software all on its own has decided I shall NOT be allowed to do this alone.. Oddly enough if I write an entire sentence I am allowed to do so, however a single word (reference designator) followed by a ? is not permitted.. Strange...
www.kta-hifi.net Last edited by kevinkr; 26th June 2010 at 06:20 PM. |
#5 |
Hello Marknoir,
What are the chances of getting the rest of the schematic, the audio portion? Craig |
#6 | |
No, VR2, one of the pair (chain) providing reference 340V dc voltage. I replaced them with a chain of five 68V zeners. |
#7 |
#8 |
Here's my email- (removed by mods). Thank you very much!
Craig |
#9 |
VR1 and VR2 actually clamp the voltage on the grid of the 6L6GC during warm up, when the 6EJ7 has fully warmed up and the feedback loop is closed you will see that the voltage at that point is below the zener threshold by some 40V or so depending on the condition of the particular 6L6GC and the line voltage.. They also will clamp the output voltage in the event the error amplifier tube (a 6EJ7) fails - in this case the output voltage will be much higher though than is the case for normal operation, however it is below the rated voltage of the caps that follow the regulator. (I've worked on a number of MFA Luminescence pre-amps over the last 15yrs or so..)
www.kta-hifi.net Last edited by kevinkr; 26th June 2010 at 09:28 PM. |
#10 |
Might want to ask a mod to remove this as it is an easy target for spambot harvesting.. Don't know about you but anything to avoid additional spam seems worth while..
Better practice would be llwhtt_at_yahoo_dot_com for example..
www.kta-hifi.net |
| CROUZET-Motor for Transrotor Turntable Model "Hydraulic" - Replacement? | tiefbassuebertr | Analogue Source | 8 | 17th March 2010 05:56 PM |
| What is the "State of the Art" today? | Out_of_phase | Class D | 12 | 6th November 2007 09:42 PM |
| "The Juke" started..... | Andy G | Multi-Way | 27 | 23rd July 2007 09:34 PM |
| MFA Lumi - possible to "un-darken" the sound signature? | marknoir | Tubes / Valves | 16 | 23rd January 2007 04:02 AM |
| Is this motor-boating? | Nuuk | Chip Amps | 5 | 19th May 2003 05:16 PM |
| Page generated in 0.12787 seconds (80.26% PHP - 19.74% MySQL) with 11 queries |
