diyAudio Sponsor
Old 12th June 2010, 08:22 PM   #1
FullRangeMan's Avatar
Default New GM70 tube with problem
HI,
I receive yesterday a new graphite plate GM70 pair tubes made in 1986-Ulyanov, one tube looks OK, but the other have a loose piece of glass inside!!
Never seen this before and do not know what to expect from this tube. The piece of glass is small, about 2mm large, triangular, like a splinter of glass, and today it is no more loose, it is glued or stuck at the bottom of the tube, near the output leads.
I looked inside the tube with a light and see there is a sticky orange film/skin inside at bottom of the tube where the glass piece is adhered. I carefuly inspection the tube and do not see anything abnormal or broken, the two getter blurs are OK, as new, the tube is new, the socket pins are unused.
Unfortunately I do not have a amp or a tube tester to warm this tube, only a DMM.
Do it is usual have pieces of glass insise a tube?
What I can expect from this tube?
What I can do with a DMM?
I thanks in advance any tip or suggestion,
Gustavo
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 12th June 2010, 08:36 PM   #2
Palustris's Avatar
I can't speak specifically about the GM70, but from reports here and on other forums it seems as if it is not uncommon for one of these large tubes to have a glass shard in it. Since it is glass it is not in danger of shorting any of the electrodes and further since it appears to be stuck to the bottom of the tube I would guess that it is OK.
Old 14th June 2010, 03:16 PM   #3
Thanks Palustris for your input, I appreciated it.
Gustavo
Old 14th June 2010, 03:32 PM   #4
I also think it's ok, I've seen few 211 and GM70s with small glass pieces inside.
If getter is ok, hope it works fine.
tubes.rs
facebook.com/tubes.rs
Old 14th June 2010, 04:28 PM   #5
kevinkr's Avatar
Should be ok, one thing to also look out for in these tubes is bubbles in the glass (I have one with this issue) as these are likely to fail in use due to thermal stress in the glass. I expect it would make for an exciting couple of moments.
www.kta-hifi.net
Old 15th June 2010, 03:43 PM   #6
Thankyou boys for your help so far.
Gustavo
Old 16th June 2010, 04:24 PM   #7
Hello Kevin,
Just read your nice site about the SCD-1 mods, and see that your site support the Stereo format and not the Multi-confusion-Channel format, so I wish compliment you for it. The best musical experience is a Stereo tube amp yet. We need new supporters for the Stereo format to grow-up.
Cheers, Gustavo
Old 17th June 2010, 03:13 AM   #8
Miniwatt's Avatar
That's good news. I once dropped a 211, after which I heard a piece of glass rattle inside. I put it aside as I was afraid to use it, I'll blow off the dust and take another look at it. Not that I have a 211 amp..
Old 17th June 2010, 03:38 AM   #9
HollowState's Avatar
Also check the pins at the base with an ohmmeter. Only two diagonal pins should show continuity which are the filaments. And look at the two springs at the very top center. They should be of even height. Of one is loose or very raised, the filament is probably gone.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 17th June 2010, 12:10 PM   #10
jlsem is offline jlsem  United States
jlsem's Avatar
The 211 and other similar tubes have glass insulators on the leads attached to the elements of tube. They seem to be made of fairly thin glass and little shards often break off during handling. Not a problem unless you are trying to sell it, because audiophile buyers get freaky about little **** like that.
John
want to do PP-GM70 day Tubes / Valves 79 10th October 2011 06:30 PM
GM70 sockets? otto88 Tubes / Valves 41 7th September 2009 09:08 AM
GM70/GM70 parafeed SET? louischia Tubes / Valves 10 4th December 2008 03:12 PM
Page generated in 0.09959 seconds (78.01% PHP - 21.99% MySQL) with 10 queries
