Parts source for M.Hubers P.S. regulator?
Old 22nd June 2003, 05:50 PM   #1
mwmitchell is offline mwmitchell
Default Parts source for M.Hubers P.S. regulator?
Does anyone know where I can get the parts for Manfred Hubers regulator? I can't seem to get them anywhere i usually get stuff (mouser, digikey, mcm).
These are some of the parts i can't find:
ZPD10 (zener)
BSS135 (mosfet)?
MTP2P5O
ZTX458
ZTX558
He mentioned farnell.com, but that doesn't seem to work.
Thanks for any info!
Matt Mitchell
Old 22nd June 2003, 08:33 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Lets see,
The ZVP10 can be replaced with any 1.3W 10V zener.
Probably two 5.1V zeners can do the job.
The BSS135 is a 600V mosfet.
I doubt you need 600V.
The MTP2P50 = V-MOS, 500V, 2A, 75W, <6ohm(1A)
Look for IR substitute.
The ZTX458: MPSA44, 2SD1350
The ZTX558: 2SA1251, 2SA1625, 2SA1699, 2SB1074
You wont find those either.
Could you post a schematic, or a link to it?
It looks like that regulator is quit old. Besides that, Mr. Huber has used parts with very high specs, especially the voltages are very high. Not quite sure this is necessary.
Oh, and what is not working with Farnell?
/Hugo
Old 22nd June 2003, 11:44 PM   #3
Hey,
Thanks for the reply and very useful information!
Here is the link to the regulator that I'm thinking of building. I've looked at Allen Wrights SuperReg, but this looks more simple to me.
http://home.t-online.de/home/MHuber/bjtreg.htm
Any thoughts on this regulator?
Thanks again,
Matt
Old 22nd June 2003, 11:54 PM   #4
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Yes, what's is going to regulate?
Frank
Old 23rd June 2003, 12:53 AM   #5
I guess that it makes some sense to know what circuit it's going to supply!
I'm using this circuit for tube preamps. right now, i have a mic preamp circuit i'm working on. it's all balanced, uses Allen Wrights Cascode topology (using a MAT02 and a 6DJ8) for the input stage, then goes into another stage (6sn7) using only one phase of the input stage, the 6sn7 drives an eq circuit and a limiter, then into a phase splitter, and into a long tailed pair (6H30) driving a 1660LL transformer.
Does that help? I like this regulator because i can make sense of it, and have heard good things about it.
Matt
Parts source for M.Hubers P.S. regulator?Hide this!Advertise here!
Pre Amp,source Change,regulator uhcmos Swap Meet 1 13th July 2008 11:30 PM
Maida Regulator Parts Eli Duttman Tubes / Valves 6 2nd June 2007 12:56 PM
PSU with Simple Source Follower Regulator Onvinyl Power Supplies 33 2nd February 2006 03:57 PM
switching regulator as a current source SS Parts 13 10th February 2004 01:58 PM
DC regulator to 5v from a 32v source? rammsteinme Parts 6 13th June 2003 03:51 PM
Copyright ©1999-2017 diyAudio
