| diyAudio Sponsor | ||
Found on John Bronski´s site :
SuperTriodes & Inverted ES Speakers Can a tube really drive the output transistor if a powerfull output is needed, like for a speaker! Can some one explain to me how it works, what about termal run away in the trasistors? and idle current? Is there a working amp on the internet somewhere i can learn from? Regards Allan |
#2 | |
The tube isn't really required but does impart a 'tubey' sound (tube-type distortion spectrum) to the output. jd
/Another new issue: Linear Audio Volume 3! |
#3 |
The tube actually looks like it's in the feedback loop, the gainclone is just a current booster. I've got a PCB for this design in the works, when I get it built, I'll report on the results.
Listen to the music through the stereo, not the stereo through the music. |
#4 |
Sorry guys for not beeing precise enough. Please take a look at the middle of the page. subject "SuperTriode Meets the Aikido".
#5 |
Look like a good idea tube sound with current of gainclone. Do we need high voltage swing to drive the super triode with gainclone.
Fenris - Please report back when you are done. |
#6 |
Please keep the gain clone of of this, I refer to the circuit in the middle of the page, with an akido tubeamp with NPN or a PNP output transistors added.
Can the tubes really drive the transistors. I guess the transistors will only have 25-50 time current gain. |
#7 |
I think MOS-FETs would have been a better choice due to the gain of Beta*Ib of the bipolar transistors (Yes 25-50 is probably a good range).
However, the combination of source follower on top and common emitter on bottom is going to give some additional non-linearity and the output impedance of the two is quite different. |
#8 |
mosfet has to worry gate blowout when the cathode is cold.
PNP at the plate by itself is already perfect, no need to fix. |
#9 |
I guess peak currents in a speaker can be pretty high, do you think the tube can drive the Transistor good enough if the transistor HFE is around 25-50. I guess it will have to be a power tube to make it work?
| Matched PNP/NPN dual transistors | carlmart | Solid State | 31 | 25th January 2012 10:36 PM |
| PNP NPN Complimentary Transistors | dannywhac | Parts | 2 | 20th August 2009 06:23 AM |
| Very High-Gain PNP Transistors... | EchoWars | Solid State | 16 | 6th July 2009 03:27 PM |
| Use of PNP transistors instead of NPN in buffer circuit. | TB | Chip Amps | 13 | 8th October 2007 06:58 AM |
| Matched Transistors (quad PNP arays) | rtarbell | Parts | 5 | 17th September 2005 09:44 PM |
| Page generated in 0.10271 seconds (73.87% PHP - 26.13% MySQL) with 10 queries |
