| diyAudio Sponsor | ||
im on my way to finishing a preamp but the gain is too high could this be because the filament voltage is above 7 when it should be about 6?
thanks |
#2 |
How much is too much ? Emission will be higher with increased heater voltage but not *that* much. higher.
You can use series resistor, a diode (if you're using DC heater supply) or two diodes (if you're using AC heater supply) to drop the voltage to 6.3V.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#3 |
Tubie Noobie
Does this preamp use feedback? What is the schematic of the preamp?
Filament voltage does need to be lowered using a method as Arnulf suggested.
Living Life Doing the Waltz in 4/4 meter. |
#4 |
You might be killing the life of the heater by using a higher voltage !
For modern day applications I think most tubes without feedback could give you much higher gain than required. Negative feedback could reduce the gain depending on your circuit. If I were you I'd try to pick a tube ( for example) that can give lower gain like say a 12B4A than a 6DJ8 and avoid any feedback scheme. If you post your circuit you might get more accurate replies !
AM |
#5 |
If I were you I'd use a resistor to drop filament voltage, and use degeneration on the gain stage to reduce the gain.
I.e. remove cathode bypass caps and possibly increase cathode res value (with a bridge for the grid bias as required.) |
#6 |
the gain is way too high, i can only turn the volume up about 30% and then it starts to distort. it doesnt use feed back it is a dual paralleled single ended triode with a cathode follower.
here is the schematic of one channel, the pot is 100k |
#7 |
With a tiny fraction of a milliamp running through your cathode follower, it's not likely to perform well...
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#8 |
This surely is a waste of tubes ... split it up and make it two separate channels or change the topology. If you intend to go the second route, have a look at Broskie's "Aikido" stage - 4 tubes put to a much better effect.
This has nothing to do with the filament voltage, it has everything to do with wrong solution to a problem. If you can desribe what you're actually trying to accomplish (besides building a tube preamplifier, of course
#9 | |
i didnt design this circuit. this is a kit and im green to electronics. im just trying to reduce the gain. so i assume that making the plate less positive or making the grid more negative would result in reduced gain. the grid controls the flow of electrons so the more negative it is the less current there is and the plate attracts the electrons so the less positive it is the less current there will be. mu is the plate ability to regulate current flow over that of the grid. is this correct? so if i increase the value of the resistor to the plate then gain will decrease or if i change the cathode bias resistor to make it less positive relative to the grid would reduce gain. i guess decreasing its value would have the desired affect. or i could use a higher value potentiometer on the input i guess too. am i right? is one method better than the other? i assume you dont want to change the operational parameters of the tube too much given its characterstics. |
#10 |
You said in one of the many threads you are starting that you are building a Decware kit. Since I doubt that hand drawn schematic you posted is designed by Decware and certainly not drawn by them, maybe you should back up and tell us what is going on?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
| Power Amplifier - Pre Amplifier Unity gain - Voltage gain - where as royal way ? | tiefbassuebertr | Solid State | 9 | 9th June 2011 06:49 AM |
| Throwing away open loop gain with an opamp near or at unity gain | okapi | Pass Labs | 3 | 25th December 2009 01:23 PM |
| Gain Blockwith Variable Loop Gain | Bonsai | Solid State | 17 | 11th July 2008 02:40 PM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 01:30 PM |
| Unity Gain Operation (or low gain) | Tomo | Chip Amps | 12 | 22nd January 2004 01:47 AM |
| Page generated in 0.13339 seconds (74.54% PHP - 25.46% MySQL) with 11 queries |
