diyAudio Sponsor
Old 6th June 2010, 11:35 AM   #1
Galgo is offline Galgo  Israel
Default Cheap eBay "zoe_tsan" tube kits - worth anything?
Greetings,
While playing with my YAQIN CD2 tube buffer I really liked the TUBE sound and thinking on building a TUBE preamp for myself instead of upgrading the YAQIN.
I found this seller at eBay that seems to provide a wide range of "acceptable" quality TUBE boards in VERY decent prices...
zoe_tsang Items for sale
So - did anyone tried one of these?
I's prices so low that it might worth it even as the basis for a rebuild...
Which model will you start with as a basic preamp/buffer board? :
Buffer Pre-amplifier Headphone AMP KIT Tube 6N3
Pre-AMP Amplifier KIT Tube 6N2 srpp
Wonderful sound GE6111 Tube preamplifier Buffer kit
2Pcs 6N3+6Z4 Buffer Preamplifier Board
and there are many more at his listings...
Gal
Old 17th July 2010, 06:00 PM   #2
Hi Gal, i have ordered a lot of china stuff in the past. Some of the amps were pretty good, some not. So the answer is, order it (its really cheap) try it and you will see.. Best regards Thorsten
Chinese "knock off" kits from ebay tmort Solid State 15 27th May 2009 12:46 PM
Worth doing cheap "thermal protection fuses" in hot amps? cfcubed Pass Labs 4 15th June 2008 02:27 AM
Interesting eBay "listing" for tube amp dmitriy167 Tubes / Valves 14 3rd August 2006 04:02 PM
"Visaton - is it worth?" or... "Share your Visaton experience" mr_push_pull Multi-Way 10 7th August 2004 06:18 PM
Page generated in 0.06034 seconds (70.38% PHP - 29.62% MySQL) with 10 queries
