| diyAudio Sponsor | ||
hi,
nice drawing? the cap indicated is optional. if that cap is not included does that mean that the indicated resistor is left out too? i have both resistors but not the optional cap and i get 0 volts at B+ but 300 volts infront of the first resistor and 150 after it. the bottom leg goes to ground this recitifier circuit is in a preamp |
#2 |
Yes. It is the cap and the resistor that make the filter. You can use a resistor there to drop the PS voltage if you want, but it does nothing to filter the DC.
Aloha, Poinz AudioTropic |
#3 |
Just to be perfectly clear, do you have the bottom (negative) end of the caps connected to ground? It is not shown in your drawing.
#4 |
yes it does go to ground.
i solved the problem though. thanks |
| Tube rectifier question. | el rockyo | Tubes / Valves | 7 | 27th March 2010 08:57 AM |
| Mercury vapor rectifier tube question | nhuwar | Tubes / Valves | 13 | 7th November 2009 10:31 AM |
| Simple SE: ???Dumb Tube Rectifier question??? | BillEpstein | Tubes / Valves | 6 | 3rd May 2009 05:52 PM |
| 5Z4P rectifier tube question | Original Burnedfingers | Tubes / Valves | 3 | 7th September 2006 12:58 AM |
| rectifier tube question | jtsjf | Tubes / Valves | 3 | 11th April 2004 07:03 PM |
| Page generated in 0.07293 seconds (74.76% PHP - 25.24% MySQL) with 11 queries |
