is 6X5 a 6X4 in an octal form?
Old 22nd June 2003, 03:37 PM   #11
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Regarding the 10W resistor. Well the max I can find locally is a 5W ceramic resistor. good enough?
5W on its' own, no.
Here's what you can do, assuming a fictitious value required of 1 Ohm/10W you can use 2 2Ohm/5W resistors in //.
BTW, it doesn't have to be a ceramic one, you can probably source 10W or higher wirewound ones?
Most of those have a heatsink that allows you to srew them to the chassis for better cooling.
Frank
Old 22nd June 2003, 03:45 PM   #12
bournville is offline bournville  United Kingdom
Jayel,
The purpose of a reservoir (tank) cap is to remove any ripple from the DC output of the rectifier. I've dropped you an e-mail on the minimum changes needed for you to use a 6X5GT in preference to a 6X4.
Old 22nd June 2003, 04:04 PM   #13
jarthel is offline jarthel  Australia
Originally posted by fdegrove
Anyway, you can use an LC filter instead of the CLC filter you now show.
Suppress the first 100 uF cap... you can put it behind the self if you like...
The 470K R you can put across the last cap where it will serve as a bleeder.
100 Ohm resistor can be removed as well, the circuit will have a slow start as it is already.
with the recommendation of using an LC filter instead of CLC and the removal of 100 ohm resistor, the circuit now becomes:
6X5GT -->> choke -->> capacitor -->> resistor -->> capacitor
Is this correct?
also, do I change the capacitor values with the change to LC?
thank you.
jayel
Old 22nd June 2003, 04:12 PM   #14
wouldn't 2 20ohms 5w in parallel be equal to a 10ohms 5 w resistor?
Old 22nd June 2003, 04:18 PM   #15
fdegrove's Avatar
Is this correct?
Indeed, it is. You go from CLC to an LCR type of filter.
Quite likely there won't be any need to do so.
Although the values don't have to be that high I don't mind a bit of a "brute force" approach.
You could do a sim on PSU Designer and it wouldn't surprise me one bit if it'd spit out much smaller value caps.
Either way it won't do any damage.
Frank
Old 22nd June 2003, 04:21 PM   #16
fdegrove's Avatar
2*20R/5W in // will yield 10R/10W since they will share the dissipation between them.
Frank
Old 22nd June 2003, 04:27 PM   #17
Is there any advantage of using LCR to CLC? Also is there anything wrong with the circuit I posted except for the fact that I'll be using a 6X5GT. I know you mentioned removing the 100 ohms and replacing the 470K after the last capacitor. anything else?
Thank you.
jayel
ps. I'm not trying to question your response. It's more like understanding on how you came up with such a response which would help me understand circuits more.
Old 22nd June 2003, 04:47 PM   #18
fdegrove's Avatar
Depends on what you're targetting.
The CLC may have slightly better ripple rejection.
You could give it a try but you'll need a DVM at least to see what gives the best results.
Well, there's that cap directly after the 6X5 of course, either remove it altogether or move it after the choke where you can make another RC filter cell.
No problem.
Frank
Old 22nd June 2003, 10:03 PM   #19
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Default Re: is 6X5 an octal 6X4?
YES. In fact they often use the exact same electrode structures.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 22nd June 2003, 10:50 PM   #20
Well you first mentioned the value 1ohm 10W resistor. Why can't I use 2ohm 5W in parallel?
Jayel
is 6X5 a 6X4 in an octal form?Hide this!Advertise here!
Greetings to Everyone form Jules DJ4MC Introductions 5 15th August 2008 11:39 PM
Need help form Germany JORGETronic Tubes / Valves 6 30th June 2006 08:00 PM
All octal 6AS7 PP amp is it possible? argo Tubes / Valves 9 16th February 2005 02:08 AM
Octal Cornet RogueAngel Tubes / Valves 2 19th September 2003 01:23 AM
