diyAudio Sponsor
Old 4th June 2010, 07:53 PM   #1
srinath is offline srinath  United States
Default Need a circuit around these tubes.
I got a big mono amplifier.
Now sadly I dont like mono.
Its got a good dozen tubes in it.
Its has El34 X 2
12au7 X 2
5u4-gb X 2
12ax7 X 4
and 1 or 2 6l4gb I think ... 2 I believe.
It also has a 750V ct 300 ma transformer ...
And a output transformer too, but I am hoping to build a tube pre amp that may not use a output tranny, cos them is $$$$$ ....
Thanks in advance.
Cool.
srinath.
Old 4th June 2010, 10:05 PM   #2
firechief's Avatar
Please give us your goal again, sounds like you would like to build a stereo preamp with the parts on hand from your mono amp. Is this right?
Old 4th June 2010, 10:34 PM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
You can't build a stereo transformer-less amp from this parts.
The better option is to find one more such an amp and get stereo.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 4th June 2010, 10:50 PM   #4
Default Yes
Yes a good sounding tube preamp ... and these raytheon tubes in this amp are new. Never been burnt in. Man I have to get it made out of these.
Cool.
Srinath.
Old 4th June 2010, 11:35 PM   #5
firechief's Avatar
Cool.
Srinath.
You probally have most of the parts, let's see what the experts come up witn.
Old 5th June 2010, 02:48 AM   #6
Wavebourn's Avatar
Oops...
I did not realize that you want a preamp
There are many options available.
The better way to start is to answer the question first:
What do you want from the preamp?
Old 5th June 2010, 06:17 AM   #7
pointy is offline pointy  United Kingdom
pointy's Avatar
http://www.audiofanatic.it/Schemi/Ti...34SE_12AX7.jpg
you could make something like this (or better) with a bit of wheel'ing 'n' deal'ing on ebay
Old 6th June 2010, 02:36 PM   #8
Wow that is an amp ? cos that 373 transformer, I got that in this thing.
I also have the el34's ... The rest I will buy of course.
That is so cool, 1 12ax7 and 1 el34 per channel ... I'll check it out. Thanks so much.
Cool.
Srinath.
Old 6th June 2010, 02:50 PM   #9
leadbelly's Avatar
1st of all, that schematic you like so much from pointy is a power amp, not a preamp.
2nd, I really doubt you have a mono power amp with the tube complement you describe. I think it is almost certainly a stereo amp.
My recommendation is that you back up a bit, tell us what you have in more detail or with a picture, and what you are trying to achieve.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 7th June 2010, 02:41 PM   #10
Default Stereo
The grommes people are pretty certain its a mono amp.
I suspect it is a bridged mono though. But it does have only 1 output transformer.
Here is the schematic, I have a photofact @ home with a better pic and I would scan it in first chance I get.
Please let me know if it can be turned into stereo, cos its a very well made amp. Hate to just cannibalise tubes from it.
Cool.
Srinath.
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
CV428 tubes (Loktal 807) tubes FS mobyd Swap Meet 3 2nd January 2008 11:26 AM
shunt regulator using VR tubes (with ccs like g pimm) and circuit load jarthel Tubes / Valves 2 23rd April 2007 03:33 PM
Can I mod this circuit to use 6922 tubes? DirkD Tubes / Valves 4 23rd September 2005 07:00 PM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
Page generated in 0.09203 seconds (87.23% PHP - 12.77% MySQL) with 11 queries
