diyAudio Sponsor
Old 3rd June 2010, 04:49 PM   #1
Ipanema is offline Ipanema  Malaysia
Ipanema's Avatar
Default ECC84/6N14P for audio
How closely match is this double triodes in a single ECC84/6N14P at audio frequency? Datasheet mention about mismatch in capacitance between both triodes. But in audio frequency, does this matter? I've build a stereo cathode follower using this tube and both channel sounds the same to my ear. There's hardly any audio circuit published on this tube.
Old 4th June 2010, 03:58 AM   #2
tubesteve's Avatar
Location: since 1998 in China as an electronic consulting design and testing engineer
Send a message via Skype™ to tubesteve
doesnt matter. the ECC84 was designed for RF, there it matters
The amount of humans is increasing, but the amount of available intelligence remains a constant.
Old 4th June 2010, 06:06 AM   #3
Ipanema's Avatar
Thanks for your answer. In your opinion why this tube is so unpopular to be use as a stereo unit? It is claimed to be low noise and high bandwidth.
Old 4th June 2010, 06:44 AM   #4
tubesteve's Avatar
ECC84: this tube is a nice one and with good linearity. better than most common ECCxx types. so, why they dont use it? dont know, and its not so easy to find. i tried to get some, but ran into problems
Old 4th June 2010, 07:57 AM   #5
el156 is offline el156  Portugal
el156's Avatar
Hi!
How about the ECC804? Is it equivalent to ECC84? I have some ECC804 and i would like to use them for audio. I made some tests,and the sound is good.
Silvino
Old 4th June 2010, 08:11 AM   #6
Ipanema's Avatar
Is the Russion made 6N14P a good substitution for ECC84? There are lots of them on sale.
Old 4th June 2010, 08:21 AM   #7
tubesteve's Avatar
the ECC804 is a quite rare tube. it is ok to use in audio as well. its difficult to get more data than the basics right now. produced was it by Brimar and Telefunken, as i remember.
Old 4th June 2010, 08:37 AM   #8
danzup is offline danzup  Romania
danzup's Avatar
yes,
(sorry for confusing with 6p14p)
There are not better tube than 6P3S and 6N2P for my ears !
Old 4th June 2010, 08:43 AM   #9
Ipanema's Avatar
I mean this one. 6N14P - Wikipedia, the free encyclopedia
By googling, most of the applications for ECC84 is in FM and SRPP because this tube are design for cascode. But I'm interested to use it as a stereo pair.
Old 4th June 2010, 09:00 AM   #10
timpert is offline timpert  Netherlands
timpert's Avatar
Yes the 6N14P is a very close substitute to the ECC84, danzup is confusing it with the 6P14P, which is an EL84 substitute.
I'm currently playing with it, I bought ten of them cheaply on Ebay. It seems to be just fine for audio, with nice characteristics at lowish voltage. Only one thing should be kept in mind: there's a screen between the sections, which is connected to the grid of the section 1. This is intended to be used as a grounded-grid section, as the upper tube in a cascode. For audio, I do not expect any problems with this though.
Audio humor. Wattgate 381 Audio Grade Duplex Socket Pano Parts 18 17th March 2010 07:04 PM
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 12:29 AM
Does anyone know the plate reistance of a 6CW7/ECC84 grhughes Tubes / Valves 2 22nd May 2009 08:01 PM
Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D jaimegmr Car Audio 0 5th May 2009 06:39 PM
Page generated in 0.09728 seconds (77.66% PHP - 22.34% MySQL) with 11 queries
