Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Tubes / Valves All about our sweet vacuum tubes :)
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 1st August 2003, 07:02 PM   #11
SY is offline SY
SY's Avatar
If you're going to use a pentode as a cathode follower, you need to have the screen grid be at a positive, fixed potential above the cathode. The simplest way to do that is to put a bypass cap from cathode to screen, then feed the screen through a resistor to B+.
The REAL answer is to not try to adapt a circuit that isn't really designed to do what you want. I'm certain that with a bit of searching you can come up with a finished, tested design for an OTL tube headphone amp. In fact, I think Joe Curcio may have published one.
The usual warnings: unlike much solid state gear, tube amps carry potentially LETHAL voltages. If you're unsure of what you're doing, DON'T DO IT.
"It is not seemly, after wiping your nose, to spread out your handkerchief and peer into it as if pearls and rubies might have fallen out of your head." - Erasmus
Old 1st August 2003, 08:06 PM   #12
SY is offline SY
SY's Avatar
Follow up: I didn't see on at Curcio's site, but there are a few interesting designs posted here: http://www.headwize.com/projects/
Old 1st August 2003, 08:13 PM   #13
HDTVman is offline HDTVman
Try looking at "tubecad.com". He has done headphone amps a couple of times and if you take the time to do some reading you will get an education.
Later BZ
What ever makes the tunes flow
Old 1st August 2003, 11:23 PM   #14
G is offline G
G's Avatar
If you are going to build a headphone amp you are doing yourself a disservice by not visiting the Headwize Forums:
http://headwize2.powerpill.org/ubb/f...num=3&fdays=20
Also you should take a look at this simple and effective headphone amp project:
http://headwize2.powerpill.org/proje...aarde1_prj.htm
This is a good starting point and the sound is purported to be wonderful. Since you are using 600 ohm cans a good 470uF output cap bypassed by a good poly cap should work well. Just register for the forum and you will have all of the help you will need. I hope these links help.
G
Gavin
Old 1st August 2003, 11:38 PM   #15
diyAudio Senior Member
fdegrove's Avatar
It is one of the best on that site and I can only recommend it...especially with the Ying Mingyao PSU.
I know this circuit since it first appeared in the now defunct Dutch audio mag Audio & Techniek and it even drove my 92dB speakers to reasonable levels and with great sound.
There's still room for improvement, but as is it won't disappoint.
Frank
Thread Tools
TPA6120A2 Headphone Amp Offset Problems cynric Chip Amps 4 10th July 2007 10:42 AM
Octal tube as headphone amp output tube yagoolar Tubes / Valves 6 25th November 2006 10:11 PM
47B tube headphone amp lgqliu Tubes / Valves 2 8th July 2006 03:50 PM
Tube Headphone Amp ! -_nando-_ Tubes / Valves 5 4th April 2006 12:06 AM
My new tube headphone amp MCLL Tubes / Valves 7 24th July 2005 09:44 AM
Page generated in 0.13885808 seconds (78.70% PHP - 21.30% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
