diyAudio Sponsor
Old 2nd June 2010, 01:55 AM   #1
jdubs is offline jdubs  United States
Default 45-based SET -> Pass Labs F4
Guys, what is the recommended resistor value for wiring across the output terminals of an SET amp based on the 45 tube for an SET->F4 setup?
I've seen references to 20r and 22r.
Thanks,
Jim
Old 2nd June 2010, 01:59 AM   #2
ZUM911 is offline ZUM911  Australia
I thought Nelson recommended 8 ohm or so. that's what I used on the output of my Yamamoto 45 to the F4. Sounded fine
Old 2nd June 2010, 04:18 PM   #3
Thanks ZUM911. Do you know what power handling is appropriate for the resistor assuming my 45 amp kicks out about 2 watts / channel? Does it matter?
Old 2nd June 2010, 05:13 PM   #4
DougL is offline DougL  United States
For a 2 watt, 8 ohm load I would want an 8 watt resistor to limit power compression.
Also, think about trying higher than 8 ohms for the load.
You will probably get less distortion with a 32 ohm or higher load.
This would also allow a smaller resistor, say 2 watts, to be sufficient.
I think you should experiment a bit.
HTH
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 3rd June 2010, 10:38 AM   #5
I have 12 watt mills across the terminals. mostly because that's what i had on hand. also the output trannies of the Yamamoto are set to the 8 ohm tap, so that made sense to me
Old 6th June 2010, 06:10 PM   #6
Thanks once again, guys. How important is resistor quality, here? I assume that tight tolerance levels between the resistors is important. Not that many "audiophile" 5w and above resistors out there. I think the Mills MRA-5 and MRA-12 series look pretty good.
-Jim
WTB Pass labs First Wat (F5/F4) pcb boards elviukai Swap Meet 0 25th August 2008 08:45 PM
WTT: One set of F4 boards for one set of F3 boards KT Swap Meet 0 16th May 2008 03:49 PM
amp based partly on pass labs KEES48 Pass Labs 0 17th April 2008 12:14 AM
New SET: JE labs simple 45 or tubelab SE? cwujek Tubes / Valves 14 27th November 2007 04:15 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
Page generated in 0.08281 seconds (72.81% PHP - 27.19% MySQL) with 10 queries
