Testing Amplifiers - Speaker or dummy load - Page 2 - diyAudio
Old 2nd June 2010, 07:26 AM   #11
chris661's Avatar
Originally Posted by Rob11966 View Post
Yes, the sound issues are also a problem and a good enough stand alone reason for a dummy load. I almost wrote 'noise issues aside' in my post. I was really more interested in the 'scope trace - as many posters have confirmed the trace will be different. I guess in a perfect world, with a non-inductive load a square wave in will produce a perfect (but amplified) reproduction of the square wave. How does an inductive load (speaker) change the appearance of this wave? I will end up doing some experiments myself eventually but does anyone have any links or info?
Rob
The verticals of the square wave won't be vertical any more, because, to create a square wave, you take the original sine wave, then add lots of high frequencies to it. The right combination of frequencies and phases result in a perfect square wave.
When driving an inductive load, the amplifier will see a lot more resistance to those high frequencies.
Chris
My work: www.grimshawaudio.com
Old 2nd June 2010, 07:58 AM   #12
Yvesm is offline Yvesm  France
Yvesm's Avatar
Mmmmh . . .
That is dependent of both the source (here the amp) and the load (here the resistor or the loudspeaker).
A source having a very lo internal impedance may succeed to force a clean square wave voltage across an horribly inductive (or capacitive) load.
By "very lo internal impedance" understand less than 0.01 ohm in this context ! Many solid state amplifiers can do that while few tubed do.
But, this obviously does not mean that the current flowing into the load remains "squared" and thus the effective power transfered is unknow !
So, it's a good idea to measure both unit independently:
- How does the source (amp) react to various loads (inductive, capacitive or purely resistive).
- Plot the "true" impedance of the load (LSP).
Any way, don't bother to much about resistors used for testing,
- a 8 ohm unit, even wire wound has a "negligible" inductive component.
- Resistors produce heat and burn if temperature goes too high but for less than a minute they can be "overdriven" by a factor of 2 at no risk. 4 x 33 ohms / 3 Watts carbon will resist to some 30 Watts long enough to observe your o'scope !
Yves.
Old 2nd June 2010, 11:00 AM   #13
richwalters's Avatar
Anyone doing power measurements on a regular basis should build themselves a proper non-inductive reference load with surplus one sided pcb. This power "autobahn" in pic is built up from many 47R thick film resistors in parallel & can take 250W at 4 ohms.
Old 2nd June 2010, 11:51 AM   #14
While on the topic of tube amp outputs; enclosed is a pic of two output signals feeding into a dummy load. I get asked this question so many times. Which one is the correct one ?
One shows near perfect square wave (correct one) as expected from a well designed tube amp, and the other with some HF advance suggesting the Zobels in the 1st stage or output global nfb isn't optimised..Generally alot of equipment shows part overshoot version. The reason is that alot of amateurs still use suplus metal mainframe oscilloscope equipment which has to be earthed. So as the main amp is also earthed in a nearby mains socket, by putting the earth probe on an output tranny return (also connected to chassis) one creates a signal circulation loop enough to upset the harmonic profile. (move probe lead around and see). The cure is to use a digital scope with completely isolated circuitry or disconnect either a mains earth or the scope probe earth.
Be aware of this ! Je higher the power amp, the more the problems !
Powering up the amp under test via an isolation tranny is another way of breaking the earth link.
In any case, be aware of rising static chassis voltages that drift up posing as a shock hazard..I've seen it happen so many times with amps using input transformers.
richy
Old 2nd June 2010, 12:24 PM   #15
Loren42 is offline Loren42  United States
I wanted to add, that the best way to make a high power dummy load is to submerge the resistor in a liquid for cooling.
I would buy a new empty 1 gallon paint can at your local hardware store. They cost about 1 to 2 dollars with a lid.
Install two insulated binding posts on the top. Drill the tinniest hole in the top of the can for pressure relief.
Solder your resistor or resistors together so they hang in the middle of the can when the lid is closed.
If you want to be fancy you can make a network of different impedances and just add more binding posts at the lid for versatility.
Fill the can 90% with mineral oil that you can buy at the local drugstore. The mineral oil will dissipate the heat from the resistor to prevent thermal destruction.
Radio Shack sells 8 Ω non-inductive resistors that work well for this.
Old 2nd June 2010, 12:59 PM   #16
TheGimp is offline TheGimp  United States
TheGimp's Avatar
HeathKit Cantenna!
Old 2nd June 2010, 01:02 PM   #17
Originally Posted by TheGimp View Post
HeathKit Cantenna!
Much the same, except a different impedance. I have built my share that way and they work great (if you don't spill the oil).
Old 2nd June 2010, 02:15 PM   #18
Pano is offline Pano  United States
Pano's Avatar
For those of us in the USA these are a nice choice.
8 Ohm 100W Non-Inductive Dummy Load Resistor
I have several and the 4 Ohm model as well. They also make a 200W.
Not the same as a real speaker load, but a consistent load. Watch out, they can get hot!
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 2nd June 2010, 02:35 PM   #19
TheGimp's Avatar
I use a pair of these:
RESISTOR POWER ADJ 10 OHM 100W - D100K10RE
Since I adjust them to 8 ohms, they are derated to 80W each.
That encased one is probably a lot more durable, and easier to heat sink in additionto being cheaper.
Old 2nd June 2010, 09:04 PM   #20
Rob11966's Avatar
Hey, that's almost exactly what I was planning to do today! I went to Jaycar yesterday and got 8 x 68 ohm 10W resistors. I will be able to get an 8 ohm (or close enough) and 16 ohm test load - and that's fine at the moment as I only have these 8 and 16 ohm speakers. The power handling will be fine for my tube amps even without the oil but I will add it any way just to be sure.
Rob
Power load, dummy load (pic) luka Power Supplies 43 9th February 2012 02:50 PM
Tri Dummy Load raudio1969 Parts 0 25th February 2009 01:14 AM
A simple active DC dummy load for PSU testing Bootstrapper Power Supplies 42 17th August 2008 08:57 PM
dummy load reddish75 Solid State 72 3rd April 2008 01:15 AM
Dummy - load JensRasmussen Solid State 24 23rd February 2007 01:04 PM
Copyright 1999-2017 diyAudio
