| diyAudio Sponsor | ||
Just purchased the below item out of excitement and I am very new to valve. http://cgi.ebay.com.sg/ws/eBayISAPI.dll?ViewItem&item=260611175609 Pre-amp Tube Amplifier Kit 6N3 for DIY New I am planning to purchase a TA2020 board to put together... Need advice from veterans and fellow audio experts to get the best out of this combination. TA 2020 I have not purchased yet. Suggestions highly appreciated... Thank you. |
#2 |
If your still interested in this, I have a arjenhelder ta2020, Lepai, and various TA2024 and a TA2050. I just ordered a 6N3 Pre-Amp, how did you like your's?
THanks, Nicholas G. |
#3 |
Yes i did buy two of these from different ebay store. Used it with Arjen's board and it sounds a lot warmer. But always curious to know your view. One of them had a better rated transformer. Best regards... |
#4 |
Hi, I was going to start a new thread but this could be related to the same kit, so I'll try hear first. I have just bought this 6N3 pre kit:
Tube 6N3 Buffer Audio Preamplifier Pre AMP Kit For DIY on eBay (end time 13-Sep-10 18:06:44 BST) I think I have everything sorted out but before I start (Famous last words ) but I can't figure our which way around the 2 x LEDs should be solered in place. There isn't + or - sign, see pics, 1st one near AC inlet below right in photo.![]() and the one under the valve has a surface mount 1K resistor already fitted to underside of the board. ![]() Hope someone can give me a few pointers Cheers |
#6 | |
| Tube 6N3 use pre for ChipAmp | vthieu | Tubes / Valves | 13 | 4th April 2012 02:31 AM |
| Need help with a Tube preamp Kit (6Z4, 6N3) | Alfetta87 | Tubes / Valves | 16 | 14th February 2012 09:22 AM |
| 6N1/6N3 substitution | woodturner-fran | Tubes / Valves | 7 | 31st January 2007 01:15 PM |
| MTM stand mount or floor stand | garfieldcat | Multi-Way | 5 | 7th July 2004 12:45 AM |
| Page generated in 0.10850 seconds (73.67% PHP - 26.33% MySQL) with 10 queries |
