diyAudio Sponsor
Old 28th May 2010, 06:21 PM   #1
Jaime is offline Jaime  Uruguay
Jaime's Avatar
Default Transformer phase splitter
These days some people believe transformer phase splitter is the best alternative (Amity by Lynn Olson and others). They uses high quality transformers (Lundahl LL1660…).
But a small and inexpensive transformer may be possible? (EDCOR PC or PCW series)
Has anyone done comparisons and measures?
I write in English worse than Tarzan
Old 28th May 2010, 06:43 PM   #2
el156 is offline el156  Portugal
el156's Avatar
Hi !
Well,i have never used transformers for Phase splitters,but i think they must have many thousands of turns of wire (very thin),and many thousands of turns have big capacitance...... but i am also curious about it, we will see the specialists answers!
Cheers
Old 28th May 2010, 08:04 PM   #3
I've been using EDCOR XSM10k/10k and XSM10k/600 and find them very good for the price. I've probably run out of time I can tag my utube clips, but this guitar amp uses the XSM10k/10k in the phase splitter.
YouTube - Lucky13 tubeamp
It both measures very well, and sounds fantastic. Even though it has a pretty flat frequency response for a guitaramp, it sounds very crisp. (Usually amps that are flat sound wooly).
I haven't had the time to test them for HiFi, but I plan to, and I expect them to be good to go.
I've even used the same transformers running single-ended with good results, though their frequency respons is not as good run SE. Spot on for guitar though where a little roll-off in both ends is a good thing. (Run PP or 'balanced' like they are intended they have flat freq response).
The 6922 fits very nicely in the mentioned combination.
I used to think of transformers as some iron blob with miles of wire, and imagined in my head the electrons having to pass thru all that thin wire...Well, it's not like that, it is an electromagnetic thingy where the field is excited by the audiosignal and the signal passes thru just as immediately as thru any other passive device. Hmmm, not a good explanation, but don't think of a tranny as miles of wire....ahrg, perhaps someone will explain more textbooky for us?
Anyhow, my Nickle goes for IT-coupling being just as good as RC-coupling. Actually better than RC b/c an IT will deliver power to the load, represents a lower drive impedance, and gives the grids of the power tubes a very low DC resistance path to gnd.
Old 28th May 2010, 08:48 PM   #4
Miles Prower's Avatar
ISTs are a viable alternative, and can measure and sound good. The keys to excellent performance are to use a good IST. Secondly, drive its primary with a VT that has a low r(p) (low-u triodes such as the vertical deflection finals) and use fixed bias on the driver.
Low r(p) contributes to good low frequency performance since the lower the r(p), the smaller the percentage of Lpri it represents. Fixed bias gets rid of the cathode bias resistor, which if not bypassed, increases the effective r(p) of any triode, and if bypassed, adds capacitive currents to the cathode circuit, and with triodes, capacitive cathode currents are capacitive plate currents. This can cause resonances with primary inductance that can cause some nasty distortion.
Of course, if you're doing a design that includes ISTs, it had better have some excellent open loop performance since ISTs don't play very well with gNFB.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 28th May 2010, 09:23 PM   #5
Shoog's Avatar
Input transformers are a better option and are considerably cheaper than interstage transformers. A good set of IT will cost more than a pair of output transformers, where as inputs of acceptable quality can be had for less than $60.00 a pair.
Shoog
Old 29th May 2010, 01:21 AM   #6
Miles, Would LED bias of the stage driving the IT be a reasonable alternative to fixed in regard to low effective rp and low reactance?
mike - www.keepingsundayspecial.org
Old 29th May 2010, 01:49 AM   #7
LED bias would most likely work just fine for that.
www.dolphin-hsl.com
Old 29th May 2010, 06:33 PM   #8
Why use cathode resistors for a phase splitting duty? Each phase of the IST goes to each plate and the cathodes go together. From the cathodes there is one resistor to gnd and for best performance you want some resistance here.
Old 30th May 2010, 06:43 PM   #9
waltube is offline waltube  Italy
waltube's Avatar
One of the best for thi purpose is Sowter 3575 with OCC wire.
In attach you can see two diagram.
One the input is 20 Vac in input / 1KHz.
the other is 30 Hz 5 Vac in.
The last is a digram of two channels; the signals are the same.
The "ingresso" file is a schematic of a project of big amp ( 8 x EL34 /channel) developped for Audioreview magazine in Italy.
Ciao
Walter
Old 31st May 2010, 04:19 PM   #10
beetel is offline beetel  Singapore
Shoog
Can you provide some links to these type of transformer from where these could be purchased ?
thanks
K & K Audio Transformer phase splitter? wttaylor Tubes / Valves 0 5th March 2010 09:55 PM
Stereo 7O with transformer phase splitter? wttaylor Tubes / Valves 2 26th February 2010 11:55 PM
Is this a phase splitter? tom-vdl Solid State 9 15th October 2009 08:21 PM
Phase Splitter Name Gold_xyz Tubes / Valves 17 21st February 2008 09:48 AM
phase splitter question stoo Tubes / Valves 3 2nd November 2005 03:46 AM
Page generated in 0.12519 seconds (84.63% PHP - 15.37% MySQL) with 11 queries
