Output impedience ?
Output impedience ?
Old 21st June 2003, 03:23 AM   #1
woody is offline woody
Default Output impedience ?
I know this a little off topic but I have a question. If I used a 6dj8
with a 2.2k plate resistor my output impedience would be ~ 1.1k ok!
if I replace the 6dj8 with a mosfet say a irf510 how would I figure
my output impedience? ie. 2.2k in parallel with ?
Thanks,
Woody
Old 21st June 2003, 03:49 AM   #2
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Default Re: Output impedience ?
Thanks,
Woody
The output impedance will be +- 2.2k...
2.2k will be in parallel with a imperfect constante current source...so in parallel with a very high impedance...the 2.2k will dominate the output impedance
Jorge
Old 21st June 2003, 05:57 AM   #3
On Hiatus
SY's Avatar
Output impedience ?
If I used a 6dj8 with a 2.2k plate resistor my output impedience would be ~ 1.1k ok!
That depends on the plate current and the cathode degeneration. I think it will, in most cases, be somewhat higher than that. Either way, that will be one unhappy 6DJ8!
Unless of course you want a lot of distortion.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Output impedience ?Hide this!Advertise here!
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Help measuring output impedience woody Tubes / Valves 2 22nd February 2005 11:30 PM
Cathode bipass capacitor and transformer impedience woody Tubes / Valves 9 26th December 2003 01:07 PM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
Output impedience ? woody Solid State 1 25th December 2002 06:29 PM
