diyAudio Sponsor
Old 26th May 2010, 01:26 AM   #1
Send a message via AIM to spiritm2r Send a message via MSN to spiritm2r Send a message via Yahoo to spiritm2r
Default Heater of tube
Hi guys,
wanna ask opinion:
which one produce good sound: regulated or unregulated heather for tube ?
tq anyway !
Old 26th May 2010, 03:29 AM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default To regulate or not?
I tend to believe heater regulation is not necessary in straight amps if designed well and implemented well. Directly heated Triodes however I think should be regulated for the very best in hum nulling. Building fully regulated supplies however does run antithesis to the very nature of simple tube circuits.
Pre-amps however I believe should be fully regulated because of the very low signal levels thruout the system.
__________________________________________________ _______Rick....
Old 27th May 2010, 12:23 AM   #3
Miles Prower's Avatar
Originally Posted by spiritm2r View Post
Hi guys,
wanna ask opinion:
For low level stages, regulated is best for noise reduction. For the usual 1.0Vrms input, it really doesn't matter.
For DHT types, you're probably better off going with regulated DC on the filaments.
There are no foxes in atheistholes
www.dolphin-hsl.com
tube heater over voltage!please help... tubo Tubes / Valves 6 8th April 2009 11:58 AM
tube heater voltage, how much is too much? randytsuch Tubes / Valves 26 19th August 2008 02:42 AM
Tube induction heater schematics? abzug Parts 0 6th January 2008 08:54 AM
117v heater tube 117n7 AtomiKM Tubes / Valves 3 12th December 2006 03:24 AM
Some doubt about my first Tube amp (Heater). tnt76 Tubes / Valves 6 28th June 2005 08:03 PM
Page generated in 0.07519 seconds (69.54% PHP - 30.46% MySQL) with 10 queries
