| diyAudio Sponsor | ||
Hi All,
I'm getting the itch to do some major re-working of my current amp, a DIY Hifi Supply Ella. It uses a pretty conventional circuit: SRPP 6922's, 6SN7 LTP , fixed bias EL34 or KT88 with some modifications. Sounds very good so I am wondering if there are better sounding circuits out there. One that interests me is Allen Wright's PP1 that uses differential, cascoded 6922 into the EL34's. ![]() ![]() People with much more experience than me have praised this circuit . I'm thinking I could keep the existing chassis,power supply and fixed bias output stage and slot in the input stage. Allen doen't show any voltages. Can I calculate what the current is through the CCS in the diff amp part? Is fixed bias an improvement? Any other circuits I could look at? |
#2 |
diyAudio Moderator Emeritus
Allen's all-balanced design is one way of doing it. I'm more familiar with an all-balanced three-stage approach using 6SL7 LTP splitter - 6SN7 diff. driver - EL34s. Coupling between 1st and 2nd stages is done with step networks, to enable reasonable voltages to be used. I like to use cross-coupled balanced NFB loops from final plates to first stage plates. PSRR with these all-balanced designs is really good, giving negligible hum.
Another good topology is the Mullard-style circuit. It's important to use very good smoothing for the 1st stage B+, which can be sensitive to ripple. |
| questions on Mikael Abdellah circuit optimized for EL34 triode operation | ambience exists | Tubes / Valves | 14 | 15th June 2009 10:30 AM |
| PP EL34 circuit wanted | Norris Wilson | Tubes / Valves | 3 | 9th August 2007 11:29 AM |
| EL34 in place of a 6AS7G (used in the supply circuit as a pass tube). how? | jarthel | Tubes / Valves | 27 | 9th June 2006 12:04 AM |
| EL34 Feedback circuit | dr._sleep | Tubes / Valves | 3 | 17th October 2005 05:01 PM |
| Page generated in 0.05850 seconds (79.91% PHP - 20.09% MySQL) with 10 queries |
