diyAudio Sponsor
Old 22nd May 2010, 04:59 PM   #1
Default Voltage Gain on Long Tailed Drivers
Does anybody here know the typical gain values for a long tail driver/inverter
section as seen in the classic Fenders and Marshall amps?
I'm looking for a general range here and the answer can include 12AT7 - 12AX7
differences as well as small power vs big power.
In other words, how much gain(typically) is the driver circuit by itself supplying
to the output section. Electronic or in dbs is fine.
Old 22nd May 2010, 06:01 PM   #2
1/4 μ is a good 1st approximation. You do somewhat better, when RP is low.
Eli D.
Old 22nd May 2010, 06:11 PM   #3
Voltage gain of a singly-driven diff amp is expressed as:
1/2 ((mu*Rl) / (Rl + rp)) where;
Rl is the load resistance, typically the load resistor resistance in parallel with the following stage grid resistor,
rp is the plate resistance of the device at the quiescent operating point,
mu (μ) being the ratio of gm (grid transconductance) to plate conductance(the inverse of plate resistance).
Poinz
AudioTropic
Old 22nd May 2010, 07:03 PM   #4
Did some number crunching and everything looks good. Most answers were roughly .25 of mu
That formula was the missing link - I had been trying with the standard single stage formula but that didn't seem right.
28db is higher than I'd expected but it turns out to be just the right number for what I'm trying to do with an insert design.
Thanks again
Old 22nd May 2010, 08:13 PM   #5
Av is actually the same as a common-cathode (plate loaded) amp with a fully bypassed (or no) cathode resistor, from plate to plate. Voltage gain of each device is one half that. Whether it's a quarter of μ depends on the load resistance in relation to the plate resistance. I get more like a third of μ usually, because I don't like to load the devices heavily.
Aloha,
Poinz
AudioTropic
Old 23rd May 2010, 09:05 PM   #6
Using the classic 12AT7 circuit from the early BF period (plate loads = 82K & 100K, 1M grid resistors, 470 ohm cathode resistor, 22K tail resistor), the gain from the 12AT7 input grid to either output tube is 19.25. This can vary 2-3% based on different tube examples, but otherwise you can take this to be an accurate value, based on measurements taken years ago in a test cell model, where precision parts were used, and the measurements taken.
Dave
Old 24th May 2010, 01:06 AM   #7
Miles Prower's Avatar
Originally Posted by lassoharp View Post
Does anybody here know the typical gain values for a long tail driver/inverter section as seen in the classic Fenders and Marshall amps?
This is figured with loadlines, as seen here (attached). Draw the DC and AC loadlines as for a single stage to see what your gain, output swing, and estimated THD is going to be.
Once you have that, the gain per phase of your LTP will come in as half of that single-ended gain. With LTPs, half the input voltage appears as Vgk, and half appears across the tail load.
In this case, the loadline predicts Av= 50, single-ended. When this was actually constructed, the measured gain per phase turned out to be Av= 25 / phase -- a 0% error!
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 24th May 2010, 03:41 AM   #8
Thanks for posting that chart -it happens to be for the exact tube in question in the project I'm working on.
Balance in CCS Long Tailed Pairs SY Tubes / Valves 102 7th November 2010 11:13 PM
Long tailed pair schematic questions martyh Tubes / Valves 17 28th January 2009 10:27 PM
LTPZen, Zen with long tailed pair input stage Allen Newby Pass Labs 18 28th January 2007 03:19 PM
DC coupled long tailed pairs sajti Tubes / Valves 10 23rd February 2005 07:16 PM
Long Tailed Pair Modification lubbie Solid State 31 11th May 2004 07:11 AM
Page generated in 0.09921 seconds (76.34% PHP - 23.66% MySQL) with 11 queries
