diyAudio Sponsor
Old 21st May 2010, 06:46 PM   #1
pof@ is offline pof@  Denmark
Default Output transformer for PP EL34 source
While looking for output transformers for a PP EL34 amplifier I find Audio Note. Beside AN who else should I look at? I look for the kind of quality so I don't want to change the transformers later on.
Old 21st May 2010, 07:08 PM   #2
TheGimp is online now TheGimp  United States
TheGimp's Avatar
What price range?
Mid range, I've been happy with Edcor and Hammond. I'm leaning towards Edcor, and I'm waiting to test some of their low end transformers in the near future (shipped yesterday, but not in time for the weekend.
Old 21st May 2010, 07:08 PM   #3
SY's Avatar
James, Tango, O-Netics, Lundahl, Sowter... there's plenty out there.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 21st May 2010, 08:02 PM   #4
BudP is offline BudP  United States
BudP's Avatar
If you are planning to spend $150 each or so, Electraprint , O-netics, maybe Magnequest, possibly Lundahl.
The question is, what does your taste in reproduced music run to. Not the type of music, but the type of reproduction.
With Edcore and Hammond you will get a well balanced sound, quite musical, but not a great deal of inner note structure and a modest amount of compression on transients. Not in the least unpleasent to listen to.
With Electraprint you will get the same general balance, with more inner note tone gradient and somewhat less compression on transients.
With Lundahl you will get a much more vivid tonal portrayal, but not with an equal amount of internal note gradient info, great transient response and an overall clean, clear, low distortion presentation, a very European sound if you will.
O-Netics will provide a fire hose of information, with gradient information within everything, including transients. Very clear and complete, without compression on transients, but with a slightly softer sound than Lundahl due to slightly higher distortion. Known for extraordinary detail in Bass and Treble.
Magnequest will provide the classic Peerless transformer sound, very musical with great midrange tone and clarity, but with some roll off on both ends of the FR band. A very sweet musical presentation.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 21st May 2010, 09:31 PM   #5
Golana is offline Golana  United States
Bud, where would you put our Japanese and Asian friends in that mix?
Old 21st May 2010, 09:37 PM   #6
BudP's Avatar
I only have limited experience there. The older Tamura and a couple of Tango OPT's I have heard were very close in overall character to Electraprint. The one Hashimoto leans towards O-Netics, with a bit less color and not as clean an extension on transients, which are not negatives by the way. All four of them were capable of great musical beauty.
Bud
Old 22nd May 2010, 12:24 AM   #7
kevinkr's Avatar
Unless I am mistaken you are in Denmark so it seems that Lundahl from Sweden should be pretty high on your list.. IMO They are amongst the very best choices technically speaking and should not be insanely expensive compared to a lot of foreign imports.
Lundahl here: Lundahl Transformers, audio transformer and tube amplifier transformer manufacturer
Another to consider would be AE here: Automatic Electric Europe good stuff as well IMO..
Bartolucci of Italy also makes great transformers: Bartolucci
www.kta-hifi.net
Old 22nd May 2010, 09:09 AM   #8
With all the help I'm getting here I'm not afraid to start my project. Seems like I can post my questions and expect an good answer. Thanks all!
I'm into this because I think its fun. But mostly because I like music and I like to select my music before looking af recording quality. But with my ICEPower I can't stand listening to many of my favorite recordings.
Can anyone comment on the differens between Lundahl and AN?
PP Output Transformer design Hi-Q Tubes / Valves 12 28th October 2009 02:23 PM
Unbalacing a PP output transformer? dshortt9 Tubes / Valves 19 22nd August 2007 06:20 PM
EL84 PP output transformer for 6L6 PP class A engels Tubes / Valves 8 30th May 2007 09:45 AM
Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? ray_moth Tubes / Valves 4 23rd February 2007 12:22 PM
Page generated in 0.10530 seconds (77.88% PHP - 22.12% MySQL) with 10 queries
