diyAudio Sponsor
Old 21st May 2010, 02:35 PM   #1
Default use 2 ohm speakers
Can I use 2 ohm speakers with dynaco stereo 70?
The speakers are an 8 ohm speaker and a 4 ohm speaker in parallel in a custom built cabinet. That would be approximately 2.67 ohms(32 ohms divided by 12)
Old 21st May 2010, 03:20 PM   #2
TheGimp is online now TheGimp  United States
TheGimp's Avatar
I suspect it is a bad idea for the reasons that (1) it will reflect a much lower plate load to the tubes, resulting in higher distortion, (2) possibly excessive loading, (3) it will result in odd sharing of the power to the speakers with 1/3 to the 8 ohm and 2/3 to the 4 ohm one at nominal impedance.
What are the two speakers in parallel, and why?
Old 21st May 2010, 04:28 PM   #3
atmasphere's Avatar
I would work to raise the impedance. You will be loading the power tubes are barely more than half of what they are expecting (~1500 ohms instead of 3000) so they will not make power and they will make a lot of distortion.
If you set the speaker up at 16 ohms, or 12, you will have lot easier time of making power, and the amp will make less distortion. Going to higher impedance in the speaker is a very easy way of making it seem more transparent for this reason, and it almost does not matter what kind of amp is driving it!
Old 21st May 2010, 05:00 PM   #4
DougL is offline DougL  United States
I suspect you have an 8 ohm tweeter and a 4 ohm woofer with a simple crossover, correct? One of The crossover's job is to prevent a 2 ohm load from being seen by the amplifier. My answer is to try the 4 ohm taps.
HTH
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 21st May 2010, 05:09 PM   #5
tinitus is offline tinitus  Europe
Doug
Or the opposite
Many new tweeters are 4ohm
If so, all you need is a series resistor for tweeter attenuation
On many 2ways you get 5-6 ohm(8ohm nominal)
A few modern output trafos are made with a single 6ohm tap
Old 21st May 2010, 05:30 PM   #6
Default 2 ohm speakers
I actually have a diy speaker with a alpair 6 4 ohm full range speaker,and an 8 ohm woofer.
Old 21st May 2010, 05:51 PM   #7
atmasphere's Avatar
So, what do you mean by that? You have a pair of 6" 4 ohm speakers, or do you have six 4 ohm speakers? Sorry but your text above is ambiguous.
Old 21st May 2010, 06:20 PM   #8
I am sorry. the speaker is an alpair 6. It is 4 ohms. I also have an 8 ohm woofer.
2 speakers per enclosure. 1 is a 4 ohm full range driver, and the other is an 8 ohm woofer.
Old 21st May 2010, 06:44 PM   #9
No problem
As Doug said, you need a crossover
Drivers will not be in paralel the way you think
cap and inductor causes impedance rise
And You may need some BSC compensation
A small series resistor on your alpair6 might be part of that
5-6 ohm is realistic
But I dont know if fullrange forum is the right place to teach about crosssovers
But you cant just paralel the two drivers
You would get severe phase issues
Old 21st May 2010, 07:40 PM   #10
atmasphere's Avatar
Yes, I would cross over the drivers, probably about 300Hz or more, so that the fullrange unit has no excursion to deal with. Then it will be more transparent. That way your impedance would be 8 ohms to 300Hz, then going to 4 or 5 ohms above that. The ST-70 will have no problem dealing with that at all.
8 ohm Crossover with 4 ohm Speakers nkx1 Parts 2 24th February 2010 11:04 PM
4-ohm Speakers on 6-ohm Amp? (newbie question) diesel_88 Multi-Way 23 25th October 2007 08:54 AM
Connecting 8 ohm speakers to a 4 ohm amp mulliganmaster Multi-Way 7 1st July 2007 09:33 PM
Matching my 8 ohm amp to 16 ohm speakers. DocJDG Solid State 3 5th December 2001 01:54 PM
4 Ohm or 8 Ohm speakers impedance for Aleph 5? Piter Pass Labs 2 1st November 2001 07:15 PM
Page generated in 0.10374 seconds (75.79% PHP - 24.21% MySQL) with 10 queries
