diyAudio Sponsor
Old 20th May 2010, 11:23 PM   #1
eeyore is offline eeyore  Australia
Default Using a CCS on SE Output Stage
Just wondering what the benefits and problems with using a CCS with a SE output stage. Providing it can sink enough power (I am thinking of it in a low power <3W SE stage), can it provide sonic advantage, or does it provide more problems then it solves?
DF
http://diy-audio-blog.blogspot.com
Old 21st May 2010, 03:07 AM   #2
kmtang is offline kmtang  Canada
kmtang's Avatar
You would need approx 700V B+ and the heat dissipation from CCS is about 10 watts rms.
Johnny
Old 21st May 2010, 03:24 AM   #3
Okay, so more voltage is needed, or enough to accommodate the full range of voltage swing for the tube. I assume that the CCS is installed at the cathode, and not between the PSU and the output transformer?
What are the benefits? More linear operation of tube?
DF
Old 21st May 2010, 03:44 AM   #4
DHT112A is offline DHT112A  United States
Like this????
Active loaded all DHT 300B
It extremely inefficient.
Old 21st May 2010, 08:49 AM   #5
danzup is offline danzup  Romania
danzup's Avatar
It is really the worst idea i have seen from long time .
Nothing to improve on classic SE !
The least number of components , the better !
There are not better tube than 6P3S and 6N2P for my ears !
Old 21st May 2010, 12:12 PM   #6
Globulator's Avatar
You have a concept error - you want to be pumping current through the OPT primary, not voltage - so a CCS is a waste of time and energy, and works against you - you want the current to change!!
An SE output tube is a perfect voltage -> current amplifier.
Old 21st May 2010, 04:28 PM   #7
kevinkr's Avatar
You could use a CCS in a parafeed arrangement with the OPT, note however that you would need ~twice the supply voltage to achieve the same plate voltage swing as you would get with a plate choke.
A CCS can also be used in the cathode circuit, but must be bypassed by a large, high quality capacitor in order to get the required gain, rp, and ac plate voltage swing. (AC current across the OPT primary will vary as a function of signal level, DC current would be fixed) Some people do just this, but I can see little benefit in an SE amplifier. There is one specific case where this may make sense - a PP amp where toroidal OPTs are being used and where dc current balance is extremely critical in order to prevent core saturation that quickly occurs with small dc imbalances. (Another way would be fixed bias with a cathode current sensing servo which would be much more complex.)
An SE output tube while definitely my preferred output device is not really a perfect voltage > current amplifier, one only has to look at the plate curves to realize that. Good yes, perfect no...
www.kta-hifi.net
Old 24th May 2010, 08:16 AM   #8
So another words, it is not a great idea for the output stage...
DF
Old 24th May 2010, 09:04 AM   #9
Globulator's Avatar
The way I see it is that the output transformer (OPT) is a current driven device rather than a voltage driven one. This is a debatable point but that is my view.
Therefore you want the tube (a voltage controlled current source) to just be a tube. Adding a CCS turns it into a voltage source to drive the OPT with which I feel is rather a waste of time.
The best idea is to choose a nice linear tube and bias it so that at the operating voltage (most of the B+ voltage in fact) gives you a nice straight input voltage/output current character. Beyond that you have to bridge the outputs and use a phase splitter - i.e. use a class A push-pull topology.
swinging CCS PP output stage peterr Tubes / Valves 9 10th October 2008 05:20 PM
Help on CCS PP differential driver stage for SE 845 amp swordsman Tubes / Valves 4 21st April 2008 08:22 AM
CCS in the output stage alexmoose Tubes / Valves 4 5th July 2006 11:56 PM
Which high power CCS for output stage? andyjevans Tubes / Valves 12 24th November 2005 11:45 AM
Why no CCS in PP output stage? leadbelly Tubes / Valves 11 8th April 2005 07:16 AM
Page generated in 0.11369 seconds (78.19% PHP - 21.81% MySQL) with 10 queries
