First amp build... help please!
Old 20th May 2010, 08:59 PM   #1
dosilegecko is offline dosilegecko  United States
Default First amp build... help please!
So I finally finished my guitar amp. There are numerous problems!
1) there is an insane amount of 60 Hz hum
2) the output is VERY VERY low, barely audible, less loud than the 60 Hz hum
3) the first preamp tube socket is extremely loose. it barely keeps the tube in when the amp is upside down. The socket is this one: Parts-Express.com:9-Pin Tube Socket Gold Plated Ceramic 12AX7 Type w/Bracket | tube socket chassis pc mount 8pin 9pin 4pin 7pin ceramic new sensor newtube07
I think the hum is because my star ground is kind of close to the heater supply. The output is also close to heater supply wires. Im not sure if I can even salvage this chassis / build.
I'll try to get pictures up!
Old 20th May 2010, 09:33 PM   #2
Here are the images of my poorly crafted amp
Old 20th May 2010, 09:43 PM   #3
llwhtt is offline llwhtt  United States
Schematic please.
Craig
Old 20th May 2010, 09:53 PM   #4
firechief is offline firechief  United States
firechief's Avatar
if the box is painted, did you make sure to make ground contact to bear metal?
Old 20th May 2010, 09:54 PM   #5
Globulator is offline Globulator  United Kingdom
Globulator's Avatar
Until you source a socket that works, all bets are off!!
Buy another socket..
Old 20th May 2010, 11:10 PM   #6
schematic:
Old 20th May 2010, 11:44 PM   #7
I just ordered a new socket, and the chassis is painted, but I sanded a spot and soldered the ground from the wall there, you can see the green wire in my pictures coming from the power socket. The star ground connected to the chassis via a screw. Its the thing with about 10 brown wires going into it.
I really think its because the sockets bad, and the heater wires are literally right next to my star ground... bad layout on my part.
Old 20th May 2010, 11:58 PM   #8
Looks like you have the two sections of V1 tied together in parallel but incorrectly. Pin 1 should be tied to Pin 6, 2 to 7, 3 to 8; it looks like 1 to 8, 2 to 7 and 3 to 6, am I right? I don't think that will work very well. Since you are replacing V1 socket no biggie but the tube might have been ruined. Check all other sockets for correct wiring while you are at it, we've all been there done that.
Craig
Old 21st May 2010, 12:33 AM   #9
GOOD SPOT! Wow, I wonder what I was thinking. Wait, I know! It was 3:30 AM! Let me fix that stuff and I'll get back to you guys! (probably have to do it tomorrow)
Old 21st May 2010, 01:00 AM   #10
boywonder is offline boywonder  United States
boywonder's Avatar
Are your heater wires well away from the signal wires, ie, tucked into the corners and running along the edges of the chassis coming out to the sockets only where needed? If you have to cross heater and signal wires, try not to run them parallel near each other, ie cross them at (or close to) right angles.
First amp build... help please!Hide this!Advertise here!
Help: Choosing an amp chip for a multichannel amp build the7trumpets Class D 6 2nd February 2014 03:55 AM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 04:59 PM
Build a Loud, Simple & Cheap amp for a friend EWorkshop1708 Car Audio 5 19th April 2008 05:53 PM
Want to build car amp to run a couple of 12" subs menaztricks Chip Amps 10 5th November 2005 05:39 PM
Build or buy? Logitech Z-680 & College student donga Multi-Way 3 19th August 2004 09:09 PM
