diyAudio Sponsor
Old 20th May 2010, 02:04 AM   #1
exeric is offline exeric  United States
Default multiple independent grid biasing from 1 mosfet
In a recent thread parallel output tube advantages and disadvantages were discussed. The thread starter wanted to implement it using mosfet drives (ala powerdrive). Some thought it should be implemented with a mosfet for each driven tube to balance the drive manually. Here is a possible circuit that can balance each tube bias individually and manually while using just 1 mosfet (2 for PP). The rheostats shown could just as easily be potentiometers. Comments welcome.
File Type: jpg multiple grid biasing from one mosfet.jpg (107.8 KB, 69 views)
Old 20th May 2010, 03:11 AM   #2
leadbelly's Avatar
Isn't this only applicable for situations where the grid represents a high impedance? In other words, not A2, AB2, or screen drive, but just good old A1 or AB1 grid drive?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 20th May 2010, 05:04 AM   #3
You might be right. I hadn't thought about it correctly. It looked like it would work but it will require some kind of mod that might be much more complicated than it is worth. Maybe someone else can come up with a modification that can make it work without adding more active devices.
Last edited by exeric; 20th May 2010 at 05:12 AM. Reason: There are problems with the design
Self balancing multiple MOSFET output transistors. nigelwright7557 Solid State 3 11th May 2009 12:07 AM
Biasing of IR2110 Mosfet Driver Razor_Edge Class D 16 20th July 2006 12:09 PM
Power MOSFET class AB biasing ingrast Solid State 29 4th February 2005 05:45 PM
confused on mosfet biasing!!!!! AudioGeek Pass Labs 4 19th July 2004 09:50 PM
biasing a mosfet? AudioGeek Solid State 2 17th July 2004 06:21 AM
Page generated in 0.07358 seconds (69.99% PHP - 30.01% MySQL) with 11 queries
