diyAudio Sponsor
Old 16th May 2010, 07:12 PM   #1
mltube is offline mltube  United States
mltube's Avatar
Default Amperite Ballast
I have an Amperite Ballast Tube Type 8-4.
I haven't had any luck finding data on the net.
Would anyone happen to have the information or know where I could find it?
Thank you
Old 16th May 2010, 11:07 PM   #2
I had all the data on those tubes and gave it away a couple of months ago. Maybe I'll ask the guy for it back and scan it for you.
Basically those were current regulators, often used in heater circuits to compensate for unstable power line. We mostly don't have that problem any more, so those have fallen out of favor.
Ballast tubes in general were used as dropping resistors for heater strings in consumer radios, especially small ones, back in the 1930s. They also used resistance line cords.
Old 4th July 2010, 11:39 PM   #3
I found the data! If you want the info, let me know.
Amperite delay relays engels Tubes / Valves 14 13th February 2008 06:40 PM
Page generated in 0.07280 seconds (66.65% PHP - 33.35% MySQL) with 10 queries
