| diyAudio Sponsor | ||
Can anyone speak from personal experience about the performance of these transformers? I am building a DHT amp with 45's or 2a3's and I have narrowed my choices on outputs. I am torn between a set from Jack at Electraprint or a pair of these Magnequest Robinhoods, both available for around $200. I realize the Robinhoods are open frame but mounting under the chassis is not a problem, and my goal is midrange sound quality also, not 20hz response, so these need not be huge. Any recommendations on these two?
#2 |
I have parafeed Robin Hoods in my 45 amp. I have never made a comparison by inserting other OPTs, but it's the amp I come back to after building or borrowing others.
| Output transformers | hrnous | Tubes / Valves | 8 | 22nd April 2010 08:08 PM |
| Output transformers... which one...? | oodi | Tubes / Valves | 4 | 17th March 2010 04:40 PM |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| Which is the best for output transformers | AD1865 | Tubes / Valves | 32 | 28th October 2003 09:17 PM |
| Page generated in 0.06953 seconds (65.96% PHP - 34.04% MySQL) with 10 queries |
