Can you explain what this is ? - diyAudio
Old 13th May 2010, 09:27 PM   #1
Default Can you explain what this is ?
Can someone please explain (guess?) what the tubes function is in this schematic ? Sold as a preamplifier but heard rumors its just a buffer....Would love to know the truth from someone who can read such things !
Any help appreciated
* Darn that's only part of it - I'm sure I had a full schematic somewhere....I'll have a look...
Old 13th May 2010, 09:34 PM   #2
tomchr is offline tomchr  Canada
tomchr's Avatar
I think it's an SRPP that's drawn incorrectly. The gain of each SRPP stage is fairly high but the overall gain of the circuit is set by the global negative feedback.
If my assumption of a schematic error is false and it's not an SRPP, then I'd like to know what the idea is behind the top tube with zero bias.
~Tom
Old 13th May 2010, 10:05 PM   #3
It could well be incorrect....It is Chinese
Its a "hybrid" amplifier but like I say a couple of people commented its more likely a solid state amplifier with a tube buffer strapped on the front end...Personally I have no idea
Old 14th May 2010, 12:36 AM   #4
expert in tautology
bear's Avatar
Ok, so what is the bias on the top tube?
How much current passes?
Therein lies the answer?
_-_-
but yes, I agree it may be an incorrectly drawn srpp...
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 14th May 2010, 12:45 AM   #5
notice also the tube stages are AC coupled but there is nothing that keeps the output at OVDC. I see two adj pots for the idle and one to set the output to ovdc but there is no Dc feedback to keep it there.
Old 14th May 2010, 03:44 AM   #6
Miles Prower's Avatar
Looks like two SRPPs with poorly done schemos. If they literally meant to connect the grid and cathode together, then the tube on top becomes nothing more than a diode, and the only thing that will act to provide any voltage gain is the dynamic plate impedance of that diode, which won't amount to very much gain at all.
If that was the intent, then it's possible that it's using the nonlinear diode characteristic to compensate the transistor nonlinearities. However, I highly doubt this was the intent as there is no VAS between the hollow state front end and the solid state back end, therefore, no useful gain at all, and definitely not enough to support gNFB.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 14th May 2010, 06:27 PM   #7
Thanks for the hep guys
So from what I can gather it IS a pre-amplifier which either has a poor design or incorrect schematics...
FWIW The model is : Yaqin VK-2100 if your interested.
Thanks again.
Old 14th May 2010, 06:34 PM   #8
SY's Avatar
Or, most likely, both.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 14th May 2010, 08:47 PM   #9
Indeed, It sounds like ****
Loads of power but its so brash....Sounds like a PA amp.
Old 14th May 2010, 08:47 PM   #10
ultralc is offline ultralc  United States
The top triode has grid and cathode connected together, it is simply a zero biased triode, acting as a nonlinear resistor load, to partially cancel the nonlinearity of the lower triode. Consider the cathode follower half of the Aikido, when used as a headphone amp, some people bypass the cathode resistor in the lower half to reduce output impedance, effectively making the lower triode a nonlinear resistor. It is similar in this case, just in the plate circuit instead of cathode. Nothing out of ordinary.
It is interesting that the amp has two identical stages in each channel. It could be a marketing ploy to increase tube count, but the 1K5 plate resistor seems to suggest that the designer originally intended to simply add a SRPP stage to make a hybrid out of a solid state amp, but the phase was wrong for feedback, so he just added another stage to inverse the phase. The gain is probably too high with both stages, so the top triode is re-wired as a nonlinear resistor to reduce the gain. Just my WAG.
Please explain what I did amo Solid State 22 16th July 2008 12:56 PM
can please someone explain this to me? krusty75 Tubes / Valves 6 18th February 2008 09:38 AM
Another please explain this crossover ... TurboFC3S Multi-Way 18 3rd October 2006 03:08 AM
Can someone explain to me? MaXiZ Solid State 3 12th November 2003 09:36 PM
Can someone explain to me this? MaXiZ Solid State 17 1st October 2003 06:43 AM
Copyright 1999-2017 diyAudio
