diyAudio Sponsor
Old 13th May 2010, 07:31 PM   #1
Default volume rise with frequency problem
I just built one of these:
Hammond AO-44 Reverb Amp to Hi-Fi Amp Conversion
However with speakers with little to no crossover, the volume gets higher as the frequency rises. It starts around 2-3k and then is about 6db hot by 18khz. I can more or less correct this with my software eq, but id like to have a hardware fix. I was under the impression that 10k/1nf on the primaries was a zobel network. If its not would a standard 2.7ohm/.1uf zobel on the secondaries fix it?
Old 14th May 2010, 05:03 AM   #2
Miles Prower's Avatar
It looks like something funky is happening in your gNFB loop. This thingy probably doesn't have enough phase margin, and you're getting a rising characteristic with frequency. You'll need to do some o'scoping while running the input with square waves to see where the ringing is worst. Since this is a reverb amp, you can bet that its OPT ain't exactly quality iron, and its leakage inductance is probably higher than what you'd expect from a true Hi-Fi OPT.
Then you'll need to parallel the 82K NFB resistor with small capacitors to see what will stop that, and remove that high frequency roll-on.
Also, something doesn't look right about that Zobel. 10R / 0.1uF across the primary doesn't look right. That probably should be connected in parallel with the secondary, not the primary. You might want to try that before doing anything else.
There are no foxes in atheistholes
www.dolphin-hsl.com
Volume Problem mooseling Chip Amps 0 13th May 2010 10:05 AM
LM1875 with NE5532 low frequency problem gekkehenk Chip Amps 10 14th September 2009 01:21 PM
Hafler XL280 mods gain/low frequency cutoff problem HaflerFreak Solid State 29 6th September 2007 11:55 PM
Frequency response relative to volume (loudness)? Hybrid fourdoor Multi-Way 5 9th May 2004 01:31 PM
Volume problem... Amphersands Solid State 6 22nd January 2004 04:35 PM
Page generated in 0.06930 seconds (68.56% PHP - 31.44% MySQL) with 10 queries
