| diyAudio Sponsor | ||
my last project is a SRPP tube preamplifier
with a special input and output buffer: cathode follower with a current source that is to have a compensation of "triode tone mark" in other word appear technically unnecessary but "magic for music"
visit my best audio idea http://www.esafono.it/DACTONE.htm Last edited by Stee; 12th May 2010 at 11:24 PM. |
#2 |
R.I.P.
I see a circuit with an input and an output cathode folllower, with a SRPP gain stage between. I see no point in having either cathode follower, the input one is not needed to drive a pot and a SRPP input, and the output Z of the SRPP should be low enough to drive a cable without the extra CF. Why add them? KISS is my key principle, and a CF (even with a CCS load) still is not 100% transparent. Regards, Allen |
#3 |
V1a, V2b and V3b can be replaced with resistors.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#4 |
I have to agree with Allen.. It seems needlessly complex which can't IMHO help the sound. Simpler is usually better.
www.kta-hifi.net |
#5 |
of course
but I think the success of the SRPP is just replacing the anode resistor load with a triode: an active load is good for the cathode in terms of sound it is true that the principle of character's compensation is not measurable but your ear will notice a more realistic scene just because works another identical unit in opposition of phase a too modern concept for designers more orthodox
visit my best audio idea http://www.esafono.it/DACTONE.htm |
#6 |
R.I.P.
I have no argument with your use of the SRPP topology as a gain stage, but cannot see why you need a CF buffer before it AND after it. Pointless IMO.
Regards, Allen |
#7 |
Input cathode follower: do not need. Ditch it.
Output CF: use a proper CCS tail load, either cascoded, discrete BJTs, a CCS IC, or if you insist on a "no sand" solution, a high g(m) pentode CCS. Triodes are horrible as CCSs. |
#8 |
Stee, how does this thing sound with 150V B+ ?
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#9 | |
R.I.P.
But if you want to do a really sonically transparent CF, I believe you need to use my SLCF, which can be seen as the last section of my FVP-5A schematic, linked here: http://www.vacuumstate.com/index.tpl...271.4389191557 Regards, Allen |
#10 |
I can't see how this thing can work . Look at the grid arrangement on the input stage V2A .
316A |
| Phase Reversal in 2nd Order Crossovers | BlueWizard | Multi-Way | 69 | 12th July 2007 04:27 PM |
| To SRPP or not? | duderduderini | Tubes / Valves | 2 | 12th March 2007 03:01 PM |
| Some HMMM on my SRPP | mod_evil | Tubes / Valves | 57 | 8th July 2006 04:31 AM |
| SRPP linestage help | DoomPixie | Tubes / Valves | 7 | 5th July 2005 02:49 PM |
| SRPP is....? | peranders | Tubes / Valves | 8 | 19th December 2003 08:38 PM |
| Page generated in 0.11951 seconds (77.74% PHP - 22.26% MySQL) with 11 queries |
