| diyAudio Sponsor | ||
I saw in the archives some have built phono stages and a headphone amp. I would like to build a simple linestage and wondering what experience people have had with the C3G and if they would be willing to share any circuits?
#2 |
You could basically a linestage as in the schematic linked...
http://www.jogis-roehrenbude.de/Lese...ns-C3g/c3g.gif just put in a smaller coupling cap (1-4.7uF). I built the schematic as a headphone amplifier Kopfhoerer-Amp_C3g, von Oliver Stick with a few mods and a different psu, and it sounds very good. The C3g has very good resolution, dynamics and very sweet highs! |
#3 |
Stixx. I was hoping you would post. First link doesn't work though.
I'm quite excited about this tube from what I read. Do you think its a candidate for transformer output? Anything you learned when you built yours? Much appreciated. |
#4 |
Pharod, it should be well suited for transformer output, like a 5K:600. In fact I recently built another C3G headphone amp with vintage Saba output transformers and regulated supplies, but it doesn't (yet) have the magic of the cap coupled one. It just lacks part of the bottom and also still has some hiss, just didn't have the time and money to go for better opt's... When I built the first one (the one in the second link) it sounded okay but not overwhelming... I then converted the entire psu to MKP capacitors and used Sanyo Os-con in the cathode (2 x 220uF 16V). This transformed the sonics in quite an amazing way... it is still one of my favourites. Output caps are Siemens MKV and highly recommended, you can still find them on Epay from time to time (german bay |
#5 |
Thanks Stixx. Have you ever tried LED or diode tube bias on the cathode?
#6 | |
| c3g connections | garbage | Tubes / Valves | 8 | 16th October 2010 08:51 AM |
| C3m C3g tubes | exurbia | Tubes / Valves | 2 | 28th February 2010 09:18 AM |
| Anyone used C3G to drive a 2A3 before? | d3aPentode | Tubes / Valves | 1 | 7th December 2009 07:24 AM |
| C3g | stecairoli | Tubes / Valves | 2 | 17th September 2006 07:02 PM |
| c3g producing sparks | garbage | Tubes / Valves | 2 | 11th April 2005 03:03 AM |
| Page generated in 0.08921 seconds (73.67% PHP - 26.33% MySQL) with 10 queries |
