| diyAudio Sponsor | ||
HI !
I have been spending lots of time to make the best input stage for my new amp! I want to use a 12AT7 (ECC81) ,and i need a plate voltage of 90V,because it is direct coupled with next tube (12B4A as phase splitter),and i want to have about -3v in the grid of the 12AT7, because i will use a CD player, an the output of it is about 2V. I have B+ of 280V! What value of plate resistor and cathode resistor should i use to get this values? And i would like to have plate current of about 3ma! Is this possible? Thanks |
#2 |
Check out this link:
How to "Screw Around" Your Tube Load Line You can work out most stuff using Ohms law. An anode resistor at 3mA dropping (280-90) = 190V will be: R = V / I = 190/3E-3 = 63k Now for a plate voltage at 3mA on an ECC82 lookup the load lines and locate Ia = 3mA and Va = 90V, so we get a Vg = 1V. So to get 1V on the grid (actually -1V) you need a cathode resistor that gives 1V at 3mA, or R = 1/3E-3 = 330R. Job done. |
#3 |
Sorry to say but -3V and 90V is not gonna happen with ECC81, it is cut off.
I would suggest a more "low voltage tube" like ECC88/6dj8 where you could achieve a reasonable working point at -2 to -2,5 V on the grid with 90V on the plate. /Olof
I'm not allowed to do magic, union rules... |
#4 | |
Thanks |
#5 |
Use my post to calculate the operating point of an ECC88 - you just need the ECC88 load lines - google 'ECC88 datasheet'.
The ECC88 has higher gain than the ECC81 I think - by quite a bit. ETA: Looked it up - you need -2.8V grid for 3mA at 90V, Rk = 2.8/3e-3 = 933 Ohms, pick 910R. Last edited by Globulator; 11th May 2010 at 09:35 AM. |
#6 | |
I will make a few tests later on with ECC88, probably it is the best choice i have to do what i want! i will post the results! I was looking inside an AUDIBLE ILLUSIONS preamp, and they use ECC88 with parallel triodes with 22K to anodes and 510R cathode to ground with 800mf parallel ! Thanks |
#7 |
Your other choice if you want to use an ECC81/12AT7 is to increase the plate voltage to accommodate the bias (2mA, BTW, is a good current for linearity) and then use a step network to couple to the next stage.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#8 | |
Problem with ECC88 is that you want to run fairly high currents to get decent linearity. 5mA minimum, 8-10 is better.
#9 | |
Yes,i would like to run ECC88 with higher current (about 5ma), but with grid bias of about -3V ! How can i do that with Vb 280V and tha plate voltage cannot be more than 90V!Must i lower the Vb? Thanks |
#10 |
R.I.P.
Do not worry about that 90V anode V rating. I have run them safely for years with 150 anode V's, and none less than Tektronix have used even high voltages on them to military reliability. Go for it!
Regards, Allen |
| Help with input stage driver for EL84 output stage | AudioGeek | Tubes / Valves | 2 | 20th March 2010 01:38 AM |
| How to design input stage with specific input impedance/pot value | mahleriana | Tubes / Valves | 0 | 16th November 2009 09:37 PM |
| Adding a third input to a differential input stage? | maudio | Solid State | 15 | 11th October 2006 02:16 AM |
| current bias j-fet input 2sk170 ,2sj74 at input stage | YUTK | Solid State | 11 | 2nd June 2005 03:34 AM |
| Page generated in 0.10158 seconds (79.59% PHP - 20.41% MySQL) with 10 queries |
