Does anyone have any FFT plots from real Class-AB tube amps? - Page 6 - diyAudio
Old 13th May 2010, 12:27 AM   #51
Michael Koster's Avatar
Originally Posted by smoking-amp View Post
Hmm, I'm not seeing any combining of feedback signals in Schades schematic thru the driver xfmr. Although the two sides of the OT should nominally be the same anyway. What seems to be the main problem to me is the disparity in gm when handing over control from one tube to the other. Schade's biasing graphs seem to address that for smoothest net gm.
Oh, so right. The feedback signals are subtracted separately from a common drive voltage. There is no feedback current in the transformer.
So if the drive signals are mirrors of each other, the main issue must be the gm bump, which can be addressed by selecting an op point for best composite gm.
I wonder if that's all that's happening here. What happens if the idle current is reduced? Is there a minimum distortion point?
Old 13th May 2010, 02:41 AM   #52
Michael,
Is it safe to assume that even without local feedback (only GNFB), there would be an optimal bias setpoint for minimum distortion.
I was playing around with THD vs. Bias Current when the amp is in AB. I have only really measured THD with bias >60mA on a KT88. At 80mA I found that the THD increased slightly from 70mA. In addition, as expected, max power decreased as a result of reduced b+ (due to PT load).
Living Life Doing the Waltz in 4/4 meter.
Old 13th May 2010, 06:09 AM   #53
teemuk is offline teemuk  Finland
In addition to turning off compression of the simulation data and all the other tips mentioned previously, you need to set the simulation's time frame such that it starts and stops saving data at the wave's zero crossing point. Otherwise, LTspice will interprete the "partial" wave as distortion.
A good reference is also plotting the FFT of the actual input, which in SPICE software should be ideal. Very often it's not.
EU AMP Ecodesign Working Plan 2009-2011 - No way for new Class A - AB - H & Tube Amps qsa Solid State 0 4th May 2010 07:47 AM
Soundstage with Class A/AB amps Samuel Jayaraj Solid State 23 9th January 2008 12:35 PM
Safe Working voltage of output Transistors in class AB amps with +/- supply rajeev luthra Solid State 3 31st July 2004 06:58 AM
Any Class AB Chip Amps ? LS Chip Amps 1 22nd July 2004 08:07 PM
Thermistors in class AB amps ? LBHajdu Pass Labs 10 24th June 2004 09:38 PM
Copyright ©1999-2017 diyAudio
