Does anyone have any FFT plots from real Class-AB tube amps? - Page 3 - diyAudio
Old 11th May 2010, 08:56 PM   #21
bigwill is offline bigwill  United Kingdom
These are some nice results! My faith in tube amps has been restored. I hope I can achieve such good figures when I build my amplifier design
I think my simulator adds a lot of high order trash due to the inaccuracies of its tube models...
Old 11th May 2010, 09:11 PM   #22
Globulator's Avatar
Your FFT plots looked like they were from a square wave - can you post up the output waveform at high power for that?
Old 11th May 2010, 10:03 PM   #23
Sure - here's the waveform of the amp just dipping into AB - looks nice and clean to me. No global feedback either, yet the spectrum is a mess!
Old 11th May 2010, 10:09 PM   #24
Here is the current waveform into each tube
Old 11th May 2010, 10:15 PM   #25
Can you superimpose the input signal's waveform (in phase) on top of the output plot. I think you will then see the difference.
P.S. The wave looks more triangular to me.
Living Life Doing the Waltz in 4/4 meter.
Old 11th May 2010, 10:19 PM   #26
Here we go, they were overlaid manually by twiddling the scales, I by chance happened to get them lined up nearly perfectly on my second attempt
Green is the input to the driver stage, red is the output current through 8R
Old 11th May 2010, 10:23 PM   #27
Okay what does the FFT of the input signal say? Maybe the source of your spectrum problem is the source (no pun meant)
Old 11th May 2010, 10:29 PM   #28
Just figured out how to plot the distortion waveform exactly:
Not too pretty!
Old 11th May 2010, 10:33 PM   #29
Thats pretty cool.
Old 11th May 2010, 10:41 PM   #30
Distortion at full power (~25V peak) into 8R, YUCK! I hope real life is more forgiving!
EU AMP Ecodesign Working Plan 2009-2011 - No way for new Class A - AB - H & Tube Amps qsa Solid State 0 4th May 2010 08:47 AM
Soundstage with Class A/AB amps Samuel Jayaraj Solid State 23 9th January 2008 01:35 PM
Safe Working voltage of output Transistors in class AB amps with +/- supply rajeev luthra Solid State 3 31st July 2004 07:58 AM
Any Class AB Chip Amps ? LS Chip Amps 1 22nd July 2004 09:07 PM
Thermistors in class AB amps ? LBHajdu Pass Labs 10 24th June 2004 10:38 PM
Copyright ©1999-2017 diyAudio
