Does anyone have any FFT plots from real Class-AB tube amps? - Page 2 - diyAudio
Old 10th May 2010, 11:32 PM   #11
What kind of output tubes? Also what is your driver stage?
I suppose if it is a 200W amp you may have an issue, however if it is a 15W amp, probably not so bad.
I had a similar moment/ feeling when I measured my amp at higher powers.
What does the FFT of the driver stage show?
Living Life Doing the Waltz in 4/4 meter.
Old 11th May 2010, 12:15 AM   #12
Globulator's Avatar
Originally Posted by bigwill View Post
And here's the plot of around 13W into 8ohms (no global feedback in both images), only just a touch into AB I'm hoping real life isn't as bad as this:
Interesting..
Well I can only guess that you are using a larger section of the tube's 'almost straight line' and it's less straight at the extremes. Have you tried moving the bias point and re-simulating?
The answer it seems (if that's the reason) would be to run the tubes at higher voltage so the actual swing is more linear..
The only other effect is OPT saturation - not sure a simulator would 'know' anything about anything else - all Cs and Rs are perfect.
Old 11th May 2010, 03:43 AM   #13
I am on my other computer so won't be able to post the measurements till tomorrow, however, I find that GNFB is only partly to blame for the harmonic spectra. When measuring the FFT at the grid of the Output Tube, I found that quite a bit of the distortion is from the drive section. With or Without NFB.
The level and number of higher order spike really go up when the LTP starts to do as Globultor says and hit the extremes. In my case the THD really starts to climb around 35-40Watts of output power.
Old 11th May 2010, 01:51 PM   #14
Here is the FFT spectra of the drive into the output tube. There is no GNFB. The power levels are recorded at the amplifier power level of 1Watt, 10 Watt and 40 Watt output into a 8R non inductive load.
I didn't make much effort to set the noise floor on the measurements and had to rescale slightly at the higher power levels. As you can see, the higher order harmonics are present even before the output tube. What I find interesting is the predominant 3rd order. That I believe is the particular T7 used in the LTP. I can roll tubes and change that. A T7 in this application is marginal at these drive levels, however, plays extremely well at "normal" power levels.
One other point when looking at your sim graphs is the scale. Your noise floor is way down past -140dB. I would think the error of the sim would have a large impact at this point.
Old 11th May 2010, 01:56 PM   #15
SY's Avatar
High 3rd order is the tube's way of telling you to get more voltage on the plate! The other thing to watch for is the grid current draw of the output tubes as you near clipping- that will definitely manifest as increasing odd order distortion at the driver.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 11th May 2010, 04:40 PM   #16
Globulator's Avatar
Sorry to be picky but what is a T7, and what is an LTP?
TIA!
Old 11th May 2010, 04:57 PM   #17
boywonder's Avatar
TIA!
T7=12AT7
LTP=long tailed pair
Old 11th May 2010, 07:31 PM   #18
richwalters's Avatar
FFT of fully optimised top flight fixed bias 100W HiFi amp; typ AB o/p; conventional Williamson diff driver; concertina p/s. ..boasting 0.1% thd with 20dB global nfb. Trace 0dB = 100W level. ref 1Khz. (Ignore glitch spike at 15Khz) tube line up 4x 6550; 2x 12BY7;1x6BL8
Everyone should be able to get this performance.
richy
Old 11th May 2010, 07:50 PM   #19
I suppose if I threw 3x the GNFb into the loop I could get close to that too.
At 100Watts my wifes pans fall out of the kitchen cabinets and I lose my happy home. Plus my little amp would go up in smoke at 100W (also bad for wife acceptance factor). Maybe I will try more feedback to see how low of a THD can be obtained at full power.
In the meantime at normal listening levels try this one. 0dB approx 50 Watts, ref 1KHz 2xKT88, 12at7, 12bh7 7.3dB feedback into 8 Ohms. FFT taken at 1Watt output. 0.0076%THD
Old 11th May 2010, 07:55 PM   #20
Svein_B is offline Svein_B  Norway
Here is a Williamson type amp with more modest 10dB of nfb.
FFT plot at 1W, and at 2dB below clipping.
Notice on both this and on Richy's FFT the IMD with 100Hz from the PS ripple (the spikes on both sides of the fundamental.
You will usually not see this with Spice.
SveinB
EU AMP Ecodesign Working Plan 2009-2011 - No way for new Class A - AB - H & Tube Amps qsa Solid State 0 4th May 2010 08:47 AM
Soundstage with Class A/AB amps Samuel Jayaraj Solid State 23 9th January 2008 01:35 PM
Safe Working voltage of output Transistors in class AB amps with +/- supply rajeev luthra Solid State 3 31st July 2004 07:58 AM
Any Class AB Chip Amps ? LS Chip Amps 1 22nd July 2004 09:07 PM
Thermistors in class AB amps ? LBHajdu Pass Labs 10 24th June 2004 10:38 PM
Copyright ©1999-2017 diyAudio
