diyAudio Sponsor
Old 8th May 2010, 06:23 PM   #1
xerocomm's Avatar
Post Wiring - Audio Note Transformer Parallel Single-Ended 300B
I am installing a pair of the Audio Note Parallel Single-Ended 300B C-Core AN Super Perma 55% Nickel 0.08mm output Transformers TRANS-305/03-D (TXO-305-3-55-H306-H306-SC) and need help with the wiring.
The Audio Note Output Transformers have the following wires:
One Side -
Red
Black
Other Side -
Black
Red
Blue
Old 11th May 2010, 07:18 PM   #2
Red B+
Bkack neg
Black neg speaker
red 8 Ohm
blue 4 Ohm
See also http://www.audionotekits.com/PDF/Man...sis_LowRes.pdf
Tango U808 and Audio Note Output Transformers for Single Ended Projects hifidaddy Swap Meet 6 14th April 2010 11:40 AM
Parallel Single-Ended Questions Sherman Tubes / Valves 12 6th March 2010 02:04 AM
Mission 300b parallel single ended duderduderini Tubes / Valves 1 17th October 2007 09:21 AM
Parallel, single-ended Pentode. How? arnoldc Tubes / Valves 2 16th December 2003 10:35 PM
Page generated in 0.07765 seconds (71.96% PHP - 28.04% MySQL) with 10 queries
