| diyAudio Sponsor | ||
I'd like buy a pair of good 2a3 triodes for my home made SE amp.Need advice which brand is the best (exept the Emission labs, 'cause it's expensive) of current productions 2a3-s?
Shuguang treasure or 2a3C with graphite anode, TJ, Fullmusic of Sofia mesh anode? Or another choice? Thanks for help! |
#2 |
Add the Sovtek monoplate to your list of possibilities. It's quite decent in the sonics dept. and it will tolerate dissipation levels that destroy NOS.
Eli D. |
#3 |
I'm not sure if monoplate is something different from what I tried but I've had a problem with Sovtek 2A3. Its current draw may be more than what their spec shows which exceeds the current handling capabilities of the regulator I was using for my SET amp. As a result, it dropped out of regulation and passed hum through to the output tubes. When switched to different 2A3, the hum was gone.
#4 |
I'm building a SET amp right now that will use the Shuguang 2A3C tubes. I've heard a lot of great things about this tube. The cost should run you $80-$100 for a pair (bought mine on ebay). It looks like they use to be cheaper but, like everything else, has gone up in price. Still not a bad price, though.
I just bought my OPT last night. I went for a James JS-6112HS. It was in the right price range and was just enough for either 45s or 2A3s. I later found out that the next biggest James model- the JS6123HS is a much better OPT, but also a bigger jump in price. We'll see how they do. When I get things up and running, I'll let you know my findings. Cheers, Matt |
#6 |
I'm using a pair of JJ 2a3-40 's. They sound very good, and I got them cheap. (30€ /piece)
However, just for reference, I'm going to order a pair of TJ meshplates. I never heard another 2a3 in my amp, so I'm curious about differences. Its going to happen in a month or so, if you want i'll get back here, and report the differences. gr. Paul |
#7 |
I advice You RCA /200$ per pair....I'm not rich to buy cheep stuff.../
They sound amazing! |
| best current production el34 | katopis | Tubes / Valves | 7 | 7th June 2008 02:49 PM |
| List of current production types | mashaffer | Tubes / Valves | 3 | 15th December 2007 05:20 PM |
| Current production EL34 | Klimon | Tubes / Valves | 1 | 12th January 2007 07:54 PM |
| Signal pentode in current production | Gold_xyz | Tubes / Valves | 2 | 12th November 2006 12:05 PM |
| Current production rectifiers | Tim Wyatt | Tubes / Valves | 6 | 10th September 2004 03:27 AM |
| Page generated in 0.09970 seconds (76.25% PHP - 23.75% MySQL) with 10 queries |
