diyAudio Sponsor
Old 5th May 2010, 04:54 PM   #1
batsong is offline batsong  United States
Default WE/Ultrapath B+ Where?
Want to try a WE/Ultrapath connection as suggested here:
[JN] RE: Sun Audio SV-2A3
My question is that there are three lines coming off of the filter cap. On to a resistor to ground, and two, to the left and right OPTs. If I wanted to connect the UP cap from the + of the cathode bypass to B+, where would be the best place? At the resistor to ground? At the filter cap? Or, least desirably, strip some insulation from the OPT leads?
Old 5th May 2010, 05:09 PM   #2
kevinkr's Avatar
Usually connect the ultrapath cap at the point where the OPT B+ lead is connected. Don't strip the wire off of the lead, that's just... unprofessional...
Add a small tie strip for each transformer and connect the B+ lead from the transformer, the ultrapath cap, and a lead back to the filter cap - much tidier.
www.kta-hifi.net
Old 5th May 2010, 05:19 PM   #3
Thank you.
The OPT leads, and a lead from the resistor to ground, are tied together and connect at the big filter cap.
Old 8th May 2010, 04:18 AM   #4
Default Success
Success! As suggested, I used some strip connectors to bring it all together. Thanks, it was really important for me to find a neat and elegant way to do this.
The sound is much more natural. No more beaming from the loudspeakers, which have almost disappeared altogether. No hum problems.
Ultrapath - Advantages? batsong Tubes / Valves 5 24th April 2010 07:56 PM
Q............PP Ultrapath pointy Tubes / Valves 2 25th November 2009 06:13 PM
Fixed Bias v Ultrapath dsavitsk Tubes / Valves 6 28th October 2007 06:33 PM
Ultrapath line amp tinitus Tubes / Valves 10 28th June 2007 10:54 AM
Ultrapath Cap Diy martin Tubes / Valves 1 23rd October 2005 08:46 PM
Page generated in 0.07255 seconds (65.65% PHP - 34.35% MySQL) with 10 queries
