| diyAudio Sponsor | ||
I need bias voltage of 2.2 - 2.5v so according to the threads I should pick a green LED and the orientation I've seen in schematics have the - leg on the cathode and + on ground (which seems weird).
I am only using 1/2 of the tube and its transformer output in a very simple linestage. So if I remove the cathode bias cap/resistor and just put in the green LED as outlined above it will work? I need between 11-13 mA of bias current. Right now a 222 Ohm resistor provides that. |
#2 |
Tubie Noobie
Sounds about right. You may want to test polarity with a batery and resistor. I have on several occasion gotten it backwards after cutting the leads of to fit the component.
Not all Green LEDS are created equal so you may have to try a few different ones. You can measure the potential it will regulate at by putting a 600R - 1k resistor in series with a 9volt battery. Then measure the potential across the LED.
Living Life Doing the Waltz in 4/4 meter. |
#3 |
Great! That's also what I was searching for is a way to easily measure them before just slugging them in.
What I've read is the longer leg is positive. If you forget or cut the leads the larger section within the LED is the negative. Running to a surplus store today so I was hoping to get a answer before I went. In the threads I've read here they said to get the 'dimmest' LED possible as they will have the lowest resistance. |
#4 |
Tubie Noobie
I still on occasion get them backwards!
#5 |
Trust me I've seen that unwanted 'flash' from LEDs.
#6 |
Phrarod, the longer led is indeed the anode (+). It should go to the tube cathode. Often times the underside of the led body is flattened at the cathode (-) which can help when the leads are cut.
BTW, did you know: if you forget the series resistor on a red led, you get an orange led. No kidding! Kenneth
Never send a human to do a machine's job. --Agent Smith |
#7 |
To be clear, it goes this way.
http://www.ecpaudio.com |
#8 |
But in the schematic showing orientation of the diode. I guess I assumed the line connecting the point of triangle is the + of that diode. At least when I put diodes in a circuit that's what always worked.
Can you tell I'm a little confused? |
#9 |
Diode - Wikipedia, the free encyclopedia
If you want diode to conduct in forward direction you'll have top connect anode to positive and cathode to negative supply, just like kavermei told you and just like what dsavitsk's picture shows. This is just like vacuum tubes, nothing to be confused about here
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it." |
#10 |
Thanks everyone!
| LED cathode bias - how to pick LED? | sharpi31 | Tubes / Valves | 32 | 9th November 2010 08:55 AM |
| LED bias and differential pairs | zigzagflux | Tubes / Valves | 2 | 6th December 2007 10:06 PM |
| LED bias indicator | scottw | Tubes / Valves | 6 | 6th December 2007 11:19 AM |
| LED Bias Modifications | dsavitsk | Tubes / Valves | 30 | 9th September 2007 06:55 PM |
| grid LED bias? | fred76 | Tubes / Valves | 13 | 4th August 2006 12:00 AM |
| Page generated in 0.08631 seconds (85.23% PHP - 14.77% MySQL) with 11 queries |
