Tube Parameter "Attenuation, Harmonic" What is it?
Old 4th May 2010, 01:52 PM   #1
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Default Tube Parameter "Attenuation, Harmonic" What is it?
I was looking at the data sheet:
http://www.radiolamp.su/pdf/112/6/6Z9PE.pdf
for the small pentode 6Z9P-E and noticed it has a parameter for "attenuation" with numbers given for second and third harmonics.
What does this parameter mean? No conditions are listed as to how the tube is set up or how this is measured.
Old 4th May 2010, 02:12 PM   #2
Glowbug is offline Glowbug  United States
Glowbug's Avatar
I'm taking a guess here, but attenuation is a reduction in signal - so the 2nd harmonic is 40dB less than the fundamental, and the 3rd harmonic is 70dB down?
Jim
The machine does not isolate us from the great problems of nature but plunges us more deeply into them. - Antoine de Saint-Exupéry
Old 4th May 2010, 03:58 PM   #3
TheGimp's Avatar
That is pretty much what I figured.
However I why why it would it be specified and what relivance it has since such harmonics are normally a byproduct of non-linearity in the tube. 40dB does not seem to be a particularly great attenuation.
As a broadband amp I can see why it would be important to suppress harmonics, but would expect IM to be as improtant, if not more important.
Old 4th May 2010, 04:13 PM   #4
revintage is offline revintage
Whatever the sheet says, this one looks very interesting/nice/linear at 15mA and just above 100V.
Old 4th May 2010, 06:06 PM   #5
TheGimp's Avatar
I guess I need to go ahead and build an input stage with one to see how it behaves. I'll have to rewire a 9-pin socket though. Filaments cathode and grid are in the same position as for the A side of a 6N1P so it isn't too bad.
Old 4th May 2010, 06:58 PM   #6
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
That's the same tube as the 6688/E180F. On ebay, they are usually listed as 6J9p, and you shouldn't pay more than about $1 each for them.
I have a bunch, and my experience is that they sound OK, but some of them develop a squeal after a few hours use, and nothing seems to be able to stop it. YMMV as I may have just gotten a bad batch. But, real 6688's don't cost a lot more.
Tube Parameter "Attenuation, Harmonic" What is it?Hide this!Advertise here!
Primitive harmonic distortion test of Dayton DVC 8" arjscott Subwoofers 6 20th September 2012 01:27 AM
extend tube sockets, or tube "plugs"? wicked1 Tubes / Valves 18 10th August 2010 12:17 AM
Transformer needed or "solid state guy needs help from tube guys" quasi Tubes / Valves 9 15th January 2010 12:56 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
Is it possible to get "tube sound" with just a tube preamp and chipamp output? Spasticteapot Instruments and Amps 43 15th May 2006 06:28 PM
Copyright ©1999-2017 diyAudio
