| diyAudio Sponsor | ||
new tubes
new output transformer new filter caps I plug in my guitar and I get no output from the guitar but get a loud buzzing and squealing.... what else should I be looking for? |
#2 |
A schematic would help here.
If the amp uses negative feedback, try hooking it up to the opposite end of the speaker winding (or if the speaker winding has a ground you will have to swap that too or reverse the connections of the primary winding - all of them if it uses screen taps) |
#3 |
..Gee.... I guess it helps to have the OT grounded huh? Nevermind noob mistake
#4 |
Only on the secondary side. Grounding any part of the primary will toast the OT.
#5 | |
When I clipped the "remote" leads from the terminal strip on the back of the chassis I apparently cut the ground that went to the ground terminal for the OT! The worst part about it is I've been trying to figure it out for 2 days! |
#6 |
Glad you got it sorted in the end
| cracked el34 -> replacement squeals | PM650 | Tubes / Valves | 1 | 19th May 2008 02:47 PM |
| How loud can you go? | paulspencer | Multi-Way | 7 | 28th June 2007 04:12 AM |
| DIY tube amp squeals when turned up | jjai | Tubes / Valves | 4 | 7th September 2005 01:32 AM |
| Occasional loud popping from spkrs (tube output stage on DAC) | HeadSh0T | Digital Source | 4 | 13th May 2003 01:57 AM |
| how loud do i need to go | badger | Multi-Way | 6 | 8th January 2002 07:24 PM |
| Page generated in 0.08137 seconds (82.02% PHP - 17.98% MySQL) with 11 queries |
