| diyAudio Sponsor | ||
Hello i have aquired a PACO SA-40
its original origins are unknown but the guy i got it from said he thinks a hotal was using it for an intercom/PA system. It powers on and all the tube elements glow but it starts smoking like its 1970 again. I've traced the smoke to be either an OPT or a capacitor. I found a schematic here But i cant quite identify the capacitor. i circled the two problem children in the photo. |
#2 |
That's C3 on the schem. It's a multi-section electrolytic (A,B,C,D) that has seen better days. You'll need to replace it, either with the same values in one "can", or with separate capacitors.
Jeff |
#3 |
ahah thanks man. Ill order some up. idk if i can find the can per say but i can probably gut that one. the shell of the can seems to be the common. four leads on the bottom and two bolts to the case. and theres a ground terminal on the case. hopefully these wont cost me an arm and leg but i was starting to freak when i thought it was the OPT
#4 |
You may be forced to buy a 4 x 20uf "twist-lock" plus an 80uf axial. You could use three of the 20uf sections and mount the 80uf axial underneath. I'd also be tempted to replace all the other electrolytic caps in the PS, just to avoid more magic smoke from escaping.
Probably a good idea to check the OPT for shorts just in case. Jeff |
#5 |
hey you were on to something.
JJ makes a can cap thats 40uf x 20uf x 20uf x 20uf at 500 volts and its only 15 dollars at tube depot. JJ Can Capacitor 40µF x 20µF x 20µF x 20µF / 500V and a 40uf sprague atom is only 9 dollars. if i bought them individually it would have been almost 50 dollars after shipping. -edit- i know this isnt quite the time to upgrade but alot of people seem to be changing from the 7199's to the 6U8A. it has a different pin out but the rest of the specs are the same. tube depot also offers triode balancing. according to the schematic one triode from each tube is used in each channel. seems this would be cheaper than buying a matched quad of 12ax7's and has the same outcome wouldnt it? Last edited by bacon665; 4th May 2010 at 10:16 PM. Reason: added more info |
#6 | ||
Jeff |
| For Sale: Stage Accompany diaphragms for the SA 8520, SA 8525 and SA 8526. | Webbie | Swap Meet | 6 | 7th March 2010 06:46 AM |
| FS: Radio Shack 40-1354a, 40-1197, 40-1242e | db6546 | Swap Meet | 2 | 26th November 2009 12:11 PM |
| need schematics for paco S-50 scope badly | buddy3388 | Forum Problems | 0 | 27th March 2009 04:14 AM |
| Paco mike tube amp | Jaime | Tubes / Valves | 0 | 23rd May 2008 02:11 AM |
| Speaker Rebuild - Radio Shack 40-1271 and 40-1024 | davidallancole | Full Range | 22 | 8th August 2007 01:56 PM |
| Page generated in 0.09110 seconds (75.29% PHP - 24.71% MySQL) with 11 queries |
