| diyAudio Sponsor | ||
diyAudio Moderator Emeritus
PSU chokes are bulky and heavy and not necessarily well made unless expensive. Gyrators seem to offer a tempting alternative, but can they effectively replace PSU chokes? Comments welcome!
#2 |
Ray,
Gyrators are definitely useful. Everything has its price. You need Volts to operate the circuitry. So, no gyrator in place of a true inductor, when constructing a choke I/P filter. Still, a gyrator allows you to emulate a large inductance, while using comparatively little space and adding little weight. Check this page (written in German) out.
Eli D. |
#3 |
I use it as filter in my PSU, works like a charm. Just that it dose not store energy like a true choke do.
shematic The middle one is B+ supply (we have 230 mains -> 1:1 120VA transformer: I get about 295 volt DC @ 230 mA out) The bottom one is the -60 volt (negative) supply, that's why it's upside down. (I like to keep the mosfet close to ground when ever possible) /Leif |
#4 | |
Cheers, Michael |
#5 |
Thanks for the information. Can anyone explain how to calculate the simulated inductance for a MOSFET gyrator? Would an IRF820 be OK? I'm thinking of using it in a stereo EL34 PP amp.
#6 |
Unfortunately gyrator can't replace a choke. A choke stores an energy, while gyrator turns it into a heat simulating inductive impedance. If to make a tank out of gyrator and a capacitor it may have low output impedance on the main frequency, but for other frequencies it's output resistance will be higher. It is better to utilize the same elements and to make a R-C filter with a big time constant, and a source follower.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#7 |
I was taught to only control the output of any one valve section in one way (volts or current)
so that the VALVE will form the audio signal of that section in this way the one side (volts or current) can be laid flat for the valve to form a good image of the audio signal with the other this practice stops solid state from forming part of the audio signal output of any stage and this requirement will be different from the voltage gain stage to the current output stage of an amplifier so I would look to have each valve section controlled at point in only one way. |
#8 |
Sorry, Pointy, I can't see the relevance to a gyrator in a PS.
__________________________________________________ __________________________________________ PS: I still don't understand how to estimate the simulated inductance -- can anyone suggest a formula based on the simple MOSFET circuit in the German site linked by Eli? Last edited by ray_moth; 2nd May 2010 at 12:18 PM. |
#9 |
#10 |
Did some sims on Leffemannens circuit and that one is ca 25H.
Brgds Lars |
| Quieting a Switching PSU? or easier to replace it with a linear PSU? | at77 | Power Supplies | 23 | 18th March 2010 05:46 AM |
| Using vintage OPTs as PSU chokes ? | pixworld | Tubes / Valves | 1 | 17th February 2008 06:32 PM |
| Chokes on psu lines | Pierre | Class D | 6 | 12th March 2006 07:54 PM |
| Heavy chokes in PSU ? | Bernhard | Digital Source | 1 | 20th January 2006 09:06 PM |
| Chokes in PSU | diyman | Solid State | 6 | 20th February 2004 05:13 PM |
| Page generated in 0.10598 seconds (76.67% PHP - 23.33% MySQL) with 11 queries |
