| diyAudio Sponsor | ||
Hey!
So, after much deliberation and dumbassedry here (Kofi Annan in: "Pushed and Pulled Back!"), Kofi has decided on the Baby Huey design for a friend's amp. Attached is my current BOM. I know I've included some parts that many would consider "boutique" or perhaps "audiophool", but I'm still pretty stupid these days and since I've used these parts before with success, I'm reluctant to change. So... more posts to come, but any feedback on the current BOM would be helpful. Google Sketchup-designed top plate and layout to follow. Yeah. Kofi |
#2 |
Pictchurzeses...
#3 |
And the latest schematics...
#4 |
Have you used those mundorf capactiros before? I was thinking of using them in my Engineers amplifier for the coupling caps. They are reasonably affordable.
- Nic |
#5 | |
Kofi |
#6 |
Here is what appears to be an exhaustive review of film caps from Humble Homemade HiFi:
Humble Homemade Hifi Enjoy. Kofi |
#7 |
I'm not sure if you are aware that there was a later schematic with mosfet source followers to drive the output tubes, and fixed bias on the output tubes. The Baby Huey (and it's predecessor by Yves) has intrigued me ever since I first read about it, I am so curious I really must do myself a favour and build one at some time.
Ian. |
#8 |
Kofi,
I second Ian444's advice to check out the later BabyHuey variant with fixed bias and mosfet followers. I checked this version out in a test-bed and found it to be more effortless & dynamic in the bass. Hence i'm building my 2nd BabyHuey according to the fixed bias version. The original BabyHuey is my "daily-driver", it's an excellent choice too, it's a bit simpler to build. You won't be disappointed with any of the BabyHuey variants, as Gingertube said: It's simple to build but hard to match. Kind regards, Yves |
#9 |
another huey, marvellous.
My huey constantly impresses those who get a listen. when picking parts, i found that the sound is senstive to the bypass caps in the el84 cathodes. do spend here. I would also say, the 6p14p-ev (ev is important) are the best output tubes you can buy under £20. Bloody marvellous. Last edited by adamus; 30th April 2010 at 02:53 PM. |
#10 |
Also, any reason (other than cost) not to go for choke in the PS. IT makes it so much easier to tweak the B+ and leads to a lovely silent supply (with fostex 95db/w i have zero hum with a choke input).
| Kofi Annan in: "Kofi's Living Room" | Kofi Annan | Full Range | 5 | 25th May 2008 05:19 PM |
| Kofi Annan in: "Kofi Makes a 300b DRD... and You Get to Help!" | Kofi Annan | Tubes / Valves | 135 | 15th October 2007 06:15 AM |
| Kofi Annan in: "300beee!" or "Kofi Gets a Toy" | Kofi Annan | Tubes / Valves | 125 | 25th August 2006 03:39 AM |
| Page generated in 0.10871 seconds (76.78% PHP - 23.22% MySQL) with 11 queries |
